Help key stuck in ignition - Page 2 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Go Back   KawiForums - Kawasaki Motorcycle Forums > Super Sport > ZX-6R All Model Years > 2003-2004 ZX-6R
Old 12-01-2012, 05:59 AM   #11 (permalink)
WhoUtink's Avatar
WhoUtink has at least 50 rep points
I think my ignition is F'ed. I have the same problem only, the key will not go to off or lock positions.
The little latch that engages the stem for the steering lock, is slightly extended, if I put a small amount of pressure on it , the key functions flawlessly, If not, its stuck. I have to used my pocket knife to reach in and push the button/latch/bolt flush in between the cylinder and the stem of the frame.
Idk if the bike was stolen before or just plain worn out but I gotta buy a new one as soon as I can afford it. I know, only a hundred or two, but I'm po'.
WhoUtink is offline   Reply With Quote
