Fork tube diameter of 2003 - 2004 zx6r 636. I have seached : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Go Back   KawiForums - Kawasaki Motorcycle Forums > Super Sport > ZX-6R All Model Years > 2003-2004 ZX-6R
Old 11-21-2012, 06:48 AM   #1 (permalink)
WhoUtink's Avatar
WhoUtink has at least 50 rep points
Default Fork tube diameter of 2003 - 2004 zx6r 636. I have seached
and searched and searched. Found 50 different answers. Fork tube diameters for the top and bottom triples. I don't have a caliper currently mine was stolen and I cant trust my eyes with a tape measure. I won't be able to source one until the end of the day.
The top I am almost sure = 50mm
The bottom triple ??=52mm
41 mm I.D. ??????
After some one with the correct info comes in I will repeatedly bump this thread with ways to ask this question so that anyone googling it will end up here. I have never been more frustrated trying to find an answer. lol. Every thread I find is people answering with this and that and the other, will fit but no numbers. I need numbers or my head will explode.
WhoUtink is offline   Reply With Quote
Old 11-21-2012, 12:48 PM   #2 (permalink)
greenmeeny has at least 1000 rep pointsgreenmeeny has at least 1000 rep pointsgreenmeeny has at least 1000 rep pointsgreenmeeny has at least 1000 rep pointsgreenmeeny has at least 1000 rep pointsgreenmeeny has at least 1000 rep pointsgreenmeeny has at least 1000 rep pointsgreenmeeny has at least 1000 rep points
USD 6's 41mm (09-12 don't know)
RWU 6's 41mm
10's 43mm, again the BPF don't know.
these measurements are the lower slider on USD & upper slider on RWU, it's the measurement most quote on forks.
greenmeeny is offline   Reply With Quote
Old 11-21-2012, 12:55 PM   #3 (permalink)
The Antistart
Green's Avatar
You are correct, top is 50...not sure on bottom.
Old 11-21-2012, 02:04 PM   #4 (permalink)
Steel's Avatar
Steel has at least 1000 rep pointsSteel has at least 1000 rep pointsSteel has at least 1000 rep pointsSteel has at least 1000 rep pointsSteel has at least 1000 rep pointsSteel has at least 1000 rep pointsSteel has at least 1000 rep pointsSteel has at least 1000 rep points
I'm bored, I'll go take a walk to my bike and measure. Granted, this will be for the 04 zx6rr.
Steel is offline   Reply With Quote
Old 11-21-2012, 02:18 PM   #5 (permalink)
Steel's Avatar
Upper fork, ~160mm, C=Pi(d), =) d=50.93mm
Lower fork, ~130mm =) d=41.38mm
And according to cheapcycleparts, the part number for the 04 6rr fork outer tube (upper: 44008-0001) is the same as for the 03 and 04 zx6r and zx6rr. So the upper diameter is the same.
http://www.cheapcycleparts.com/produ...ipe-fork-outer
And while the lower tube is a different part number, that's only because the 2004 zx6rr had a DLC (diamond-like coating) on the lower forks to reduce friction. The part numbers for the four parts that make up the connection (washer, inner and outer seal, ring snap) are the same for the 636s, zx6rs, zx6rrs, however you want to describe them.
Old 11-21-2012, 03:07 PM   #6 (permalink)
WhoUtink's Avatar
I need the measurement at the lower triple. Thanks for the replies so far
Old 11-21-2012, 03:15 PM   #7 (permalink)
Steel's Avatar
At the lower triple the fork is the same circumference and diameter as the first picture I posted, so it's still ~50mm
Old 11-21-2012, 03:34 PM   #8 (permalink)
old man roger's Avatar
old man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep points
The fork is thicker at the lower triple.
old man roger is offline   Reply With Quote
Old 11-21-2012, 03:39 PM   #9 (permalink)
50 at the top 52 at the bottom. I used a cheap plastic micrometer, I don't have access to my digital micrometer at the moment.
Old 11-22-2012, 04:12 AM   #10 (permalink)
WhoUtink's Avatar
52 is what I thought it was. Thanks again fellas.
I did not remember to bring the caliper home, so anyone one who disagrees with this measurement?
