Rotor swap for 04 636 please help : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Go Back   KawiForums - Kawasaki Motorcycle Forums > Super Sport > ZX-6R All Model Years > 2003-2004 ZX-6R
Old 01-03-2013, 11:53 PM   #1 (permalink)
odyssey82 has at least 10 rep points
Send a message via MSN to odyssey82
Default Rotor swap for 04 636 please help
I am trying to mount 310mm rotors on an 04 636 with 07 nissin calipers, I know I need 15mm spacers but in my online research I dont know what length of caliper screws to get. Please help.
odyssey82 is offline   Reply With Quote
Old 01-04-2013, 12:24 AM   #2 (permalink)
old man roger's Avatar
old man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep pointsold man roger has between 30,000 and 40,000 rep points
15 mm longer than stock?
old man roger is offline   Reply With Quote
Old 01-04-2013, 10:45 AM   #3 (permalink)
greenmeeny has at least 1000 rep pointsgreenmeeny has at least 1000 rep pointsgreenmeeny has at least 1000 rep pointsgreenmeeny has at least 1000 rep pointsgreenmeeny has at least 1000 rep pointsgreenmeeny has at least 1000 rep pointsgreenmeeny has at least 1000 rep pointsgreenmeeny has at least 1000 rep points
Isn't it 5mm for 300's & 10mm for 310's!?!
greenmeeny is offline   Reply With Quote
Old 01-04-2013, 11:15 AM   #4 (permalink)
Kawikid72's Avatar
Too many numbers. . .
1 = 2
Whore your slut out
Old 01-04-2013, 02:03 PM   #5 (permalink)
I would fight Abe Lincoln
RacinJason44's Avatar
Stock 03-04 caliper bolts are 60mm long, so you will need some 75mm ones.
Why didn't you just measure the ones you have and add 15?
OMRRA Novice # 744
Old 01-04-2013, 04:46 PM   #6 (permalink)
The Antistart
Green's Avatar
Old 01-05-2013, 06:46 PM   #7 (permalink)
Many thanks dude..in this day and age ones only jas to use a smart device and get the measurements for the bolts than dressing warm, going out in the 29deg temp and removing one. Thamks again though. Look out for tthe pics
Old 01-05-2013, 07:35 PM   #8 (permalink)
Haha, no worries!
OMRRA Novice # 744
Old 01-05-2013, 10:35 PM   #9 (permalink)
Ok so this is what im doing.. I have zx14 rotors which are 310mm. I bought some 07 zx6r NISSIN calipers and will mount that onto a 2004 636 front fork. As mentioned I need 75mm bolts and I checked bike bandit and the bolts for a zx with 310mm rotors are 10x73 , so I guess that 10 by 73mm. So ill buy a set of 2008zx10 caliper bolts and hope all the calculations are correct. I figure the 2 mm off is so that the pads cover maximum rotor space.
Old 01-05-2013, 10:41 PM   #10 (permalink)
You are going to need to find some spacers as well, since they locate the calipers, the bolts just hold it all together.
OMRRA Novice # 744
