how to remove fuel tank : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Go Back   KawiForums - Kawasaki Motorcycle Forums > Super Sport > ZX-6R All Model Years > 2003-2004 ZX-6R
Old 01-09-2013, 02:17 PM   #1 (permalink)
ziz
ziz's Avatar
ziz has at least 10 rep points
Default how to remove fuel tank
I'm sure there's a thread on here already but I can't find it I need to know how to remove the fuel tank on a 04 636 to change the air filter and spark plugs thank you
ziz is offline   Reply With Quote
Old 01-09-2013, 02:59 PM   #2 (permalink)
It's not rocket surgery.
LarryJ's Avatar
There's not enough room with the tank propped up? If not, remove the front bolt, prop the tank up, disconnect the fuel pump plug and fuel line, then remove the pivot bolt from the back of the tank. I'm sure there's another way to remove the tank from the back, probably a mount to the frame or subframe, but the pivot bolt will do the trick. Very simple once you stand back and look at it.
Old 01-09-2013, 03:44 PM   #3 (permalink)
cookiebug79's Avatar
To raise the front of the tank, unscrew the bolt directly behind the triple tree that holds the forks. This bolt might be hidden if you have a steering damper, so you would have to take the damper off first.
To remove the tank, you also have to remove the hardware from the rear of the tank:
Use the key to pop the passenger seat.
There's 10mm bolt in the front of the compartment that you need to remove. Once that is out you can slide a latch over that is holding down the front seat.
Remove the front seat and it will reveal the rear mounting hardware of the tank.
Lift up the tank and un-plug the fuel lines and fuel pump.
Old 01-09-2013, 03:53 PM   #4 (permalink)
ziz
ziz's Avatar
thank you I've seen some where that there are bolts on the side of the frame I need a long Allen wrench for is that on the 04 or was that on a different year
Old 01-09-2013, 05:48 PM   #5 (permalink)
I'm *pretty* sure that's not necessary for the 04, but not 100%.
Old 01-09-2013, 06:15 PM   #6 (permalink)
prs
Back by Popular Demand
prs's Avatar
Location: Pennsylvania, USA 2005 Kawasaki ZX 6R (636) 2005 Suzuki GSX-R 750 ----2007 Suzuki DL650 WeeStrom
prs has at least 80,000 rep pointsprs has at least 80,000 rep pointsprs has at least 80,000 rep pointsprs has at least 80,000 rep pointsprs has at least 80,000 rep pointsprs has at least 80,000 rep pointsprs has at least 80,000 rep pointsprs has at least 80,000 rep pointsprs has at least 80,000 rep pointsprs has at least 80,000 rep pointsprs has at least 80,000 rep points
I'm pretty sure these bolts are on the '05 but the '04 I don't know. Sorry. No biggie, just need the right size hex socket and an extention.
Sent from my transistor AM radio using my IDGAF app.
prs is offline   Reply With Quote
