» Site Navigation
» Homepage
» Motorcycle Forums
05-19-2007, 07:45 PM
#1 (permalink )
please help can you tell me what kind of oil 636
does any one know what kind of oil do you put in an 03 636 and does it matter what kind of coolant you use? thanks.
In the stable: "Studies show geniuses choose green"
2003 zx6r 636 Green 118whp (my baby)
Husaberg fe501 street legal 55hp
2005 Honda cbr600rr
2005 z1000 RawTI
2005 Yamaha FJR1300 Abs Blue
05-19-2007, 07:49 PM
#2 (permalink )
Search! It's gotta be literally 1000's of threads on this board about oil.
05-19-2007, 08:05 PM
#3 (permalink )
i've always run 10W40 kawachem until i switched to mobil 1 MX4T(changed recently to race 4T i believe) synthetic and been running mobil ever since
05-19-2007, 09:29 PM
#4 (permalink )
search its been discussed thousands of times
05-19-2007, 09:49 PM
#5 (permalink )
i run engine ice coolant and MOTUL 5100 oil
05-20-2007, 10:01 PM
#6 (permalink )
Just run MOTUL 5100 .. 10-40w or similar depending on your local temperature... as for coolant just run the original kawasaki coolant if want a bit more cooling just run water wetter...
05-29-2007, 03:10 AM
#7 (permalink )
is there a difference beetween car coolant and motorycle coolant also (this may sound dumb)but is the clear box under gas tank that says coolant on cap should that be filled with coolant thanks.
05-29-2007, 03:12 AM
#8 (permalink )
yes there is a difference between moto coolant and car coolant. Do Not Use Car coolant. I use Motul coolant...
05-29-2007, 03:17 AM
#9 (permalink )
Guest
ive used (using it now actually) car coolant on my bikes w/o problems
as far as where it goes, im sure u can figure that one out
Linear Mode
