GSXR brake swap - KawiForums - Kawasaki Motorcycle Forums
post #1 of 17 (permalink) Old 04-13-2010, 05:39 PM Thread Starter
deckard's Avatar
GSXR brake swap
I've been trying to improve the performance of my brakes (mushy, no feel, etc..), and have been reading with interest about upgrading calipers.
I have a front end from a 2003 GSXR1000 in my garage, and I am actually already using the master cylinder from this system on my ZX6R (see bent brake lever causing lockup, as well as clearance problems with stock m/c). Does anyone know if the GSXR calipers would be compatible with the ZX6R? I know the GSXR has 320mm rotors, while the ZX6R has 300mm...
If it is possible, that would be a quick and easy solution for me. The GSXR front end was on an SV650 track bike, and I know personally how well that system works.
Thanks.
deckard is offline
post #2 of 17 (permalink) Old 04-13-2010, 06:05 PM
Veteran Lowsider
Ninjabadger4's Avatar
get 2007+ zx6r or zx14 brakes
Ninjabadger4 is offline
post #3 of 17 (permalink) Old 04-13-2010, 06:07 PM
KUUG's Avatar
if its sitting in your garage take them off an find out. shouldnt take anymore than 10 minutes
take it from a man who <3 crack whores. this motherfucker knows.
KUUG is offline
post #4 of 17 (permalink) Old 04-13-2010, 08:15 PM
marker149's Avatar
Send a message via AIM to marker149
bleed your brakes, you'll be surprised what that can do, i can personally vouch for it. it's not always necessary to spend $100+ on used calipers
marker149 is offline
post #5 of 17 (permalink) Old 04-13-2010, 09:24 PM
unrulypostman's Avatar
OP: that's a pretty unique question that I doubt anyone will be able to answer faster than just going to the garage and checking. First issue I would imagine is if they bolt up to the mounting holes. But when/if you check, let us all know.
unrulypostman is offline
post #6 of 17 (permalink) Old 04-13-2010, 11:33 PM
Kawi Supporter
jdgun_13's Avatar
well, the tokicos are shit...seemed like a kick ass caliper when they came out but for whatever reason their longevity seems to be an issue.
try the gsxr calipers....worse case the mounting surfaces have to much material on them.
otherwise the nissin are the perfect solution.
2011 675R
2012 RSV4 Factory
Ex Kawi Pilot
jdgun_13 is offline
post #7 of 17 (permalink) Old 04-13-2010, 11:46 PM
Nillard's Avatar
Just upgraded to nissin calipers off of a 2007 Zx6R and I love them! Got them for $100 from some guy parting his bike out.
-06' ZX6R Green... SOLD!
-03' ZX6R White/blue Track only
-92' Mazda Miata w/ supercharged F20c
WWW.socaltrackdays.com WWW.ti2tt.com
Originally Posted by nevada
hey man, im going to need you to resize that pic. its too big.
Nillard is offline
post #8 of 17 (permalink) Old 04-14-2010, 07:35 AM Thread Starter
deckard's Avatar
I made a mistake, the 2003 GSXR1000 actually uses 300mm rotors, which are the same as the ZX6R. I measured up the GSXR calipers, and they look to be a direct swap to the ZX.
However, the 2003 GSXR calipers are also Tokico. They are slightly different in design, but I wonder if this swap will eventually put me in the same position I already am..
I may give it a shot, but if I can score a set of Nissins, I'm probably taking that route.
deckard is offline
post #9 of 17 (permalink) Old 04-14-2010, 08:28 AM
cenzo89's Avatar
dude just try mounting them, it's only gonna take a few minutes! you already know how they feel and you like them so just give it a shot! let us know how it worked out
'06 636 Flat Raw Plasma Blue: SOLD
'06 636 Ebony Black SOLD
'10 Ninja 250 Metallic Island Blue (hers)
'12 Aprilia RSV4
cenzo89 is offline
post #10 of 17 (permalink) Old 04-14-2010, 04:18 PM
freongee's Avatar
Send a message via Skype™ to freongee
yeah, but watch the pads in the old Gixers caliper, check it first for plenty of pad material! Caliper swap has nothing to do with rotor sizes, you need to watch the caliper mounting tab offset/distance whatever it is. Kawi uses 100mm offset calipers...
freongee is offline
