ZX10 front calipers : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 10-15-2012, 07:41 PM   #1 (permalink)
Cycleeric's Avatar
Cycleeric has at least 10 rep points
Default ZX10 front calipers
I picked up a set of front calipers for a 08 ZX10 and wondering if swapping them onto my 05 ZX6R is worth it? I've got a set of Galfer Superbike lines to install at the same time too.
I will clean and rebuild the calipers before installing them and the lines. I lowsided last weekend at CMP so I've got her pulled apart right now so no better time than now to upgrade the brakes
2006 Nissan Murano SL awd
2001 Ford F150 Lariat 4dr
1996 Ford Mustang GT convertible
2006 Suzuki GXSR600
2005 ZX6R 636
Cycleeric is offline   Reply With Quote
Old 10-15-2012, 07:51 PM   #2 (permalink)
It's not rocket surgery.
LarryJ's Avatar
Yeah they're better calipers than what came stock on your bike. Supposedly almost as good as the 07+ Nissins. Go for it.
Old 10-16-2012, 06:03 AM   #3 (permalink)
Doug_UK has at least 10 rep points
You need the 310mm rotors off the 08 ZX10R or ZX14 to fit these calipers, or machine them to fit.
Doug_UK is offline   Reply With Quote
Old 10-16-2012, 08:36 PM   #4 (permalink)
Cycleeric's Avatar
Doug are the rotors interchangable between the 2 bikes?
2006 Suzuki GXSR600
2005 ZX6R 636
Old 10-18-2012, 08:43 AM   #5 (permalink)
I fitted ZX14 310mm rotors to my Gen 2 ZX10R, with Gen 3 Tokico calipers, then fitted the ZX10R rotors to my ZX6R C1H, to get rid of the gold, with ZX14 Nissin calipers. So I'd say yes, they're a straight swap. I did try the Nissins with the 310mm rotors, but it was a bit too much for road use, the Tokicos gave more feel at the lever.
Old 10-18-2012, 05:26 PM   #6 (permalink)
Cycleeric's Avatar
Thank you Doug for the advice. I have my eye on a set of galfer wave rotors to go with these cailers and the Galfer lines so it should be a good upgrade over stock.
2006 Suzuki GXSR600
2005 ZX6R 636
Old 10-19-2012, 11:03 AM   #7 (permalink)
LarryJ's Avatar
I would buy the calipers first and test fit them to your forks. I don't believe you NEED the 310 mm rotors. The caliper carrier is usually where the difference is between models with different size rotors, the calipers are the same dimensions. For example the carriers on the 10R forks are longer to accommodate the larger rotor.
If you get the 310 mm rotors you'll need 5 mm spacers for the caliper carriers (5 mm larger radius). Now 310 mm rotors will give you some more stopping power, but I doubt it'll be mind blowing.
Old 11-06-2012, 07:38 PM   #8 (permalink)
badassjake's Avatar
badassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep points
i have 14 rotors on mine....nice, lots of brakes, kinda overkill.
"There is always room for more with 674."- Book of Kawi 6:74
badassjake is offline   Reply With Quote
Old 11-09-2012, 02:38 AM   #9 (permalink)
purposeinlife_1's Avatar
purposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep points
I have 310mm rotors from a 10R on my 636. They give a little better feel and modulation, not worth the extra expense IMO, but I got them free.
04 Acura TL. Total grandma car.
06 Frontier Nismo. Meh, it's ok.
06 636. Just sits in the garage keeping everyone else company.
06 Pitster Pro GPX 125. It's planing on killing me.
07 GSXR750 Trackbike
purposeinlife_1 is offline   Reply With Quote
