bypass tip over sensor : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 01-09-2008, 10:56 AM   #1 (permalink)
catsbaseballjsk is around zero rep points
Default bypass tip over sensor
does anybody know if you can and how you do bypass the tip over sensor.... the one thats on the front of the bike inbetween the headlights... ive been trying to buy one from the local shop and they cant find it so i was just wanting to know if you could bypass it somehow... thanks
catsbaseballjsk is offline   Reply With Quote
Old 01-09-2008, 11:22 AM   #2 (permalink)
collinjoseph's Avatar
collinjoseph has between 20,000 and 30,000 rep pointscollinjoseph has between 20,000 and 30,000 rep pointscollinjoseph has between 20,000 and 30,000 rep pointscollinjoseph has between 20,000 and 30,000 rep pointscollinjoseph has between 20,000 and 30,000 rep pointscollinjoseph has between 20,000 and 30,000 rep pointscollinjoseph has between 20,000 and 30,000 rep pointscollinjoseph has between 20,000 and 30,000 rep pointscollinjoseph has between 20,000 and 30,000 rep pointscollinjoseph has between 20,000 and 30,000 rep pointscollinjoseph has between 20,000 and 30,000 rep points
IDK about the sensor that you're talkin' about but, on the older bikes the sensor is under the front seat (I think). It has a weight mounted inside it and if the weight tips tips too far left or right the bike shuts off. So if you immobilize the weight then you have effectively bypassed the sensor. If this sensor is something like that then just immobilize the weight.
That was just a shot in the dark 'cause I've never seen the tip over sensor on an '07.
collinjoseph is offline   Reply With Quote
Old 01-09-2008, 11:40 AM   #3 (permalink)
jardis's Avatar
jardis has at least 250 rep pointsjardis has at least 250 rep pointsjardis has at least 250 rep pointsjardis has at least 250 rep points
Send a message via AIM to jardis
just curious, why would you want your bike to continue to run in the event of a crash?
It's practically stock
jardis is offline   Reply With Quote
Old 01-09-2008, 11:43 AM   #4 (permalink)
tecateman's Avatar
tecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep points
Send a message via AIM to tecateman Send a message via MSN to tecateman Send a message via Yahoo to tecateman
now you got me curious too especially if im going to do trackdays. hopefully someone has an answer
leo vince full exhaust /woodcraft rearsets / puig db screen / pazzo racing levers / shogun crash kit / ss led eliminator kit / driven gel grips / black bolt kit / relocated rear reservoir / solo cowl flush mount mod/ spiegler ss brake lines / jumper mod / bmc race air filter / kleen air mod/ ram air mods / ohlins fork springs / -1 vortex frt sprocket /8000k headlights / no clutch mod lol /
tecateman is offline   Reply With Quote
Old 01-09-2008, 11:51 AM   #5 (permalink)
because mine is broke off and the local shop are idiots and cant find this part. i havent riden my bike in months because of this
Old 01-09-2008, 11:54 AM   #6 (permalink)
I didn't ask this guy but, I know that stunters disable/bypass these switches so that they can do certain tricks...
Old 01-09-2008, 11:55 AM   #7 (permalink)
What exactly broke off? Do you have pics? I'm sure that someone on here can think of something to help you.
Old 01-09-2008, 11:55 AM   #8 (permalink)
AKA "White Dynamite"
mr.croom's Avatar
mr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep points
Send a message via Yahoo to mr.croom
Sometimes they work, and sometimes they dont. In my crash last April, my bike came to rest on its right side, hanging the throttle, making the engine bounce of the limiter until I shut it off. When I first got the bike, I had a near miss with an old man in an Isuzu Pup who pulled out in front of me. I stopped the bike within 3ft of the drivers side door of the truck, but lost my balance because I was leaned so far over the front of the bike (improper braking skills yes, I was caught off guard ) , and tipped it over. I liked to have never got that fucker cranked back! Even trying to roll it off it wouldnt crank, and then, mysteriously, she fired right up. Tip sensor I assumed.
http://i193.photobucket.com/albums/z158/mrcroom/croom_sig-2-1-1.jpg
mr.croom is offline   Reply With Quote
Old 01-09-2008, 12:02 PM   #9 (permalink)
mr.croom's Avatar
Make sure they look under "fuel injection parts" of the parts catalog. Its called a vehicle down sensor.
Old 01-09-2008, 12:04 PM   #10 (permalink)
mr.croom's Avatar
As seen here my friend.
http://www.mrcycles.com/fiche_section_detail.asp
