Go Back   KawiForums - Kawasaki Motorcycle Forums > Super Sport > 2007-2008 ZX-6R
Penn Foster
Old 03-30-2008, 09:26 PM   #51 (permalink)
Trackdaze's Avatar
Trackdaze has at least 2000 rep pointsTrackdaze has at least 2000 rep pointsTrackdaze has at least 2000 rep pointsTrackdaze has at least 2000 rep pointsTrackdaze has at least 2000 rep pointsTrackdaze has at least 2000 rep pointsTrackdaze has at least 2000 rep pointsTrackdaze has at least 2000 rep pointsTrackdaze has at least 2000 rep pointsTrackdaze has at least 2000 rep pointsTrackdaze has at least 2000 rep points
Default Short throw throttle
Ok so the OEM throttle throw is waaaay to long but there is no way I was going to spend $180- on a Yoyodyne or other aftermarlet throttle and the zip tie method well, I wasn't going to use a zip tie so.
I purchased a few things and had thing or two. All in all, I spent $2-
I bought a 1 1/2" OD piece of PVC pipe from the hardware store $2- I had some 2 part plastic specific epoxy. I pulled the OEM throttle off the bike.
Next I measure the width of the throttle part where the cable sits and cut the PVC to match, it was 1/2" exactly
I then lined up this piece with the throttle tube and cut it just below where the cable attaches.
I then dremeled the edges to a taper on the ends and used the 2 part epoxy and epoxied the PVC to the throttle tube. Here is the end result
Jimmy D - CCS #530
TPM Official Coach #530 www.teampromotion.com
'07 ZX6R - Elka triple - Traxxion AK-20 - Sharkskinz - Akrapovic full race system - Vortex clips, rears, & sliders - PCIII - Goodridge SS lines - Scotts damper - ASV levers - stompgrip tank pads.
Trackdaze is offline   Reply With Quote
Old 03-30-2008, 09:43 PM   #52 (permalink)
tecateman's Avatar
tecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep pointstecateman has at least 2000 rep points
nice does it work?
leo vince full exhaust /woodcraft rearsets / puig db screen / pazzo racing levers / shogun crash kit / ss led eliminator kit / driven gel grips / black bolt kit / relocated rear reservoir / solo cowl flush mount mod/ spiegler ss brake lines / jumper mod / bmc race air filter / kleen air mod/ ram air mods / ohlins fork springs / -1 vortex frt sprocket /8000k headlights / no clutch mod lol /
tecateman is offline   Reply With Quote
Old 03-30-2008, 10:44 PM   #53 (permalink)
Trackdaze's Avatar
Originally Posted by tecateman View Post
nice does it work?
I did it, of course it works!!!
Jimmy D - CCS #530
Old 03-30-2008, 10:58 PM   #54 (permalink)
tecateman's Avatar
well you know damn well im stealin your idea now. thanks. although i might have to use black pvc pipe on my bike lol.
Old 03-30-2008, 11:30 PM   #55 (permalink)
tecateman's Avatar
its ashame i cant run mirrors on the track. that bike would look so good in my mirrors of course until i pull away.
Old 03-31-2008, 01:30 AM   #56 (permalink)
Kretz's Avatar
Kretz is around zero rep points
I got a noob question, HOW does it work? With that little piece of PVC you only have to rotate your wrist 1/4 turn to WOT? How does that work.
BTW your bike is awesome; GL at the track show'em what a Kawi can do!!
Tony|07 Red
Full Akrapovic|PC III|BMC|+2 rear|Pazzos|GPR|Sportech DB|OES Sliders|Pig Spotters 2|
SS Fender Eliminator|
Kretz is offline   Reply With Quote
Old 03-31-2008, 08:27 AM   #57 (permalink)
Trackdaze's Avatar
It works just like a sprocket on the rear wheel, as the throttle tube gets larger in diameter it requires less of a turn to pull the same amount of throttle cable over it.
Just think, if you had a 4" piece of string and you wanted to wrap it around a 1" diameter tube, you would turn the tube 4 full rotations
If the tube was 2" diameter you would only need to turn it 2 full rotations to wrap the same 4" string.
In this case I just wanted to shorten the throttle "throw" from 1/4 turn or 90 degrees which is stock to a shorter amount. I ended up shortening it to just above 1/5th a turn, in the end it now is about 75 degrees to full WOT.
Jimmy D - CCS #530
Old 03-31-2008, 10:34 AM   #58 (permalink)
Red_DevilZx6r's Avatar
Red_DevilZx6r has at least 250 rep pointsRed_DevilZx6r has at least 250 rep pointsRed_DevilZx6r has at least 250 rep pointsRed_DevilZx6r has at least 250 rep points
u are getting different tires right?
Red_DevilZx6r is offline   Reply With Quote
Old 03-31-2008, 10:41 AM   #59 (permalink)
Trackdaze's Avatar
Already done, I already ran the bike 2 days at VIR.
Jimmy D - CCS #530
Old 03-31-2008, 10:46 AM   #60 (permalink)
Midget Rancher
hoser's Avatar
hoser has at least 20000 rep pointshoser has at least 20000 rep pointshoser has at least 20000 rep pointshoser has at least 20000 rep pointshoser has at least 20000 rep pointshoser has at least 20000 rep pointshoser has at least 20000 rep pointshoser has at least 20000 rep pointshoser has at least 20000 rep pointshoser has at least 20000 rep pointshoser has at least 20000 rep points
GREAT thread!!!
Sir Balzachary DesCrote Grundlecheese. Viscount of Lower Browneye and leader of the Midgets clicky
hoser is offline   Reply With Quote
vB code is On
