Go Back   KawiForums - Kawasaki Motorcycle Forums > Super Sport > 2007-2008 ZX-6R
Penn Foster
Old 06-07-2009, 11:35 PM   #51 (permalink)
C.J
C.J is around zero rep points
I've installed my CC rearset adjuster and I have a problem with the adjustability..
For the brake side, I can only mount it on the rear most position because of where the brake light switch is, I cannot move it forward at all.. Can anyone help, am I suppose to relocate the brake light switch? maybe I'm missing something here?
Pic to describe the situation..
KneeDragger, where's your brake light switch in this pic?
Originally Posted by KneeDragger View Post
Finalized
ps. For the lower mounting point of the original rearset, I know you need to grind the back side to move it forward, but that's not the problem I'm facing..
Another problem I encouter, plz feel free to jump in an help this situation
Can't bring in the pegs closer, since the resistance spring is in the way!?!?!
So no choice but to have the sets on the last row! Haing known this, I wouldn't of grinded the back of them!
In conclusion, if you can find a way to place the spring else where, then this is an awesome purchase, since their is a multitude of places to put the pegs.... but if not, then you might as well go with Concept 5150, since you'll be paying more and not be able to use all the options of placing your pegs!
I still like them... Will try to figure something out with the spring!
For the spring, I think you can try hooking it into one of the rearmost holes on the CC adjuster, instead of the hook on the original rearset...
Otherwise, happy with the product, very happy with Cyclecontrol's customer service, quick email reply, fast delivery, shipment arrived before expected, not bad for shipping from US to a small Asian country.. Highly recommended..
2008 ZX-6R Green | Akra Slip-On | Pazzo Long Levers | Driven Grips | Spiegler Lines | Cycle Control Rearset Adjuster | Sliders | Bobbins | CB Radio | HazelLife Camera TailBag
2006 650R Silver (Sold) | SM Bar | Pazzo levers | Driven grips | Goodridge lines | Sliders | Bobbins | CB radio | Givi top case
C.J is offline   Reply With Quote
Old 06-08-2009, 10:23 PM   #52 (permalink)
KneeDragger's Avatar
KneeDragger has at least 650 rep pointsKneeDragger has at least 650 rep pointsKneeDragger has at least 650 rep pointsKneeDragger has at least 650 rep pointsKneeDragger has at least 650 rep pointsKneeDragger has at least 650 rep pointsKneeDragger has at least 650 rep points
I removed the bracket that holds the rear brake light switch, since my bike will only be for track use!!! Sorry... no solution but...
You can always put ur switch else where and just get a safety-wire to do the distance, for the light to activate on the switch.
If you know you are suppose to grind the back of the rearsets, then you should know u need to do the same with that piece that holds the light switch, since it's thicker then the rearset. it won't go any further up, if you leave it there, so u do need to grind it off.
I grinded everything off and got my rearsets and foot pegs powdercoated
Keep The Rubber Side Down!!!
KneeDragger is offline   Reply With Quote
Old 07-01-2009, 04:02 PM   #53 (permalink)
Lance Uppercut has at least 250 rep pointsLance Uppercut has at least 250 rep pointsLance Uppercut has at least 250 rep pointsLance Uppercut has at least 250 rep points
so i just installed mine and it was a breeze becuase i have a bench grinder. i zip tied the rear brake light and left it disconnected because i dont know who brakes using only their rear brake.
however when i installed the brake pedal spring it was rubbing on the adjuster (like kneedragger stated) but it still functioned. In the middle of a ride on the highway i felt something hit my leg that came from the bike so i pulled over and checked and what do you know the spring flew off. however the pressure from the fluid keeps the pedal in the upright position and when i push it down it comes right back up then i noticed my bros cbr with woodcraft rearsets has no springs either. Should i be concerned?
Lance Uppercut is offline   Reply With Quote
Old 07-01-2009, 04:11 PM   #54 (permalink)
fallfornoone's Avatar
fallfornoone has at least 250 rep pointsfallfornoone has at least 250 rep pointsfallfornoone has at least 250 rep points
get rid of the rear brake switch, you dont need it. your gonna use the front brake and that will trigger the brake light
Yoshimura RS5 TI Exhaust, Ohlins 25mm Cart Kit, Ohlins TTX, Sato Rearsets, Pazzo Shorties, Galfer SS Lines, PCIII, -1/+2 Driven Sprockets, RK Chain, Healtech Speedo, Woodcraft Frame Sliders, hyperpro damper, Jumper Mod - ::RIDE::
fallfornoone is offline   Reply With Quote
Old 07-02-2009, 07:56 PM   #55 (permalink)
so i guess no one knows if its ok to run the rear brake pedal springless
Old 07-03-2009, 07:06 PM   #56 (permalink)
MRA669's Avatar
MRA669 has at least 450 rep pointsMRA669 has at least 450 rep pointsMRA669 has at least 450 rep pointsMRA669 has at least 450 rep pointsMRA669 has at least 450 rep points
In most cases yes. I havent run a spring in my last 4 bikes because I always used after market rearsets.
MRA #669
BIKE: 2007 ZX6R
Mods:....
MRA669 is offline   Reply With Quote
Old 08-18-2009, 01:16 AM   #57 (permalink)
warp9racing's Avatar
warp9racing has at least 50 rep pointswarp9racing has at least 50 rep points
is there a coupon code for these yet :P
07 Monster Kawasaki ZX6R - Dorothy
Akra,PCIII,KR,Pazzo,Puig,HID,CW,CA,Jumper,Vortex,B stones,Galfer,techspec,Attack
warp9racing is offline   Reply With Quote
Old 08-21-2009, 12:12 AM   #58 (permalink)
does anyone have a set of these on their bike in the silver colour?
Old 08-22-2009, 11:02 AM   #59 (permalink)
mac5726's Avatar
mac5726 has at least 1000 rep pointsmac5726 has at least 1000 rep pointsmac5726 has at least 1000 rep pointsmac5726 has at least 1000 rep pointsmac5726 has at least 1000 rep pointsmac5726 has at least 1000 rep pointsmac5726 has at least 1000 rep pointsmac5726 has at least 1000 rep pointsmac5726 has at least 1000 rep pointsmac5726 has at least 1000 rep points
Sorry man, haven't seen them in silver
Silver 07 ZX6R, KR Tuned Full System, PC III, Jumper mod, Ram Air mod, Hotbodies GP screen, LP spools, Vortex sliders, clip ons, and sprockets, Tech Spec, Galfer SS front lines, Renthal Grips, Radiator guard, K&N, Pit Bull Damper, Cycle Control Rearset Raisers, LP Pegs, Corsa III's
mac5726 is offline   Reply With Quote
Old 08-22-2009, 09:16 PM   #60 (permalink)
evil skinny's Avatar
evil skinny has at least 3000 rep pointsevil skinny has at least 3000 rep pointsevil skinny has at least 3000 rep pointsevil skinny has at least 3000 rep pointsevil skinny has at least 3000 rep pointsevil skinny has at least 3000 rep pointsevil skinny has at least 3000 rep pointsevil skinny has at least 3000 rep pointsevil skinny has at least 3000 rep pointsevil skinny has at least 3000 rep pointsevil skinny has at least 3000 rep points
brake return spring is really just to return your brake pedal to the highest resting position, so you can tune the brake light sensor to activate as soon as you touch the pedal. It will not affect rear breaking at all. I would yank it off and remove the rear brake light sensor also.
evil skinny is offline   Reply With Quote
vB code is On
