hey whats up guys, i laid my 07 zx6r down a while back and needed to bypass the vehicle down sensor and finally figured out how to do it. and since i did searched forever to find a thread on this and no one has made one and there several ppl who need this i decided to post this. This is for stunters and ppl like me who cant just glue the little internal weight down bc in my case there was a short.
**this works on 07-08 zx6r and zx14r and most likely zx10r**
step1- cut all 3 wires from the connector off the wiring harness (brown, yellow/green and blue)
step 2- connect both yellow/green and blue with a 1/4 watt 68k ohm resistor
step 3- tape off brown (ground)
AND YOURE DONE! SIMPLE AS THAT.
the resistor with lower the voltage down to what the ecu is looking for and bypass your VDS with no effects. BE ADVISED IF U GO DOWN YOUR BIKE MAY NOT SHUT OFF being that this is an FI sensor which cuts off fuel in the event of a crash.
