Official Jumper Mod Thread : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 05-15-2007, 07:47 PM   #1 (permalink)
midnightmethane has at least 250 rep pointsmidnightmethane has at least 250 rep pointsmidnightmethane has at least 250 rep points
Send a message via AIM to midnightmethane
Default Official Jumper Mod Thread
Ok I know this has been discussed before but when I took my seat off I couldn't relate to the pictures. Can someone confirm the actual procedure and where the wires are located. Which wire go get spliced. Pictures would also be extremelly helpful. And please, anything related to the jumper mod should be posted here (questions, concerns, pictures, etc...) Thanks in advance for all the contributions
2009 ZX-6R (Lime Green): Vortex Spools / Attack Performance RS / Pazzo Shorties / GSG Mototechnik FS / OEM Seat Cowl / Galfer SS Brake Lines / Racefit Growler Slip-On / Evotech Exhaust HB / Evotech Tail Tidy / Ariete 90º Valve Stems / Michelin Power One 2CT / Motul 300V 15W50 Full Syn / Contour GPS Camera
** Plans: Ohlins Damper Re-valve / Evotech Gas Cap
midnightmethane is offline   Reply With Quote
Old 05-15-2007, 10:47 PM   #2 (permalink)
santo666's Avatar
santo666 is around zero rep points
this should help some out, http://www.i-hacked.com/content/view/165/45/
other then that i don't know where any good info is
santo666 is offline   Reply With Quote
Old 05-15-2007, 11:09 PM   #3 (permalink)
that's cool...tanks....i'd also like to see it done on the '07 with good step by step direction and detailed pics
Old 05-15-2007, 11:54 PM   #4 (permalink)
RMSZX6R's Avatar
RMSZX6R has at least 50 rep points
It is exactly the same there isn't anything done different on that bike or the 07...
Just remove side plastics to take off front seat.
Remove both seat bolts and remove seat.
Tucked under the seat on the brake side of the bike there is a 4 pin connector thats just capped.
Jump the green/green wire and the black/yellow wires across with 16 gauge wire and put cap on.
Make sure cap locks back on.
Install your seat and plastics and enjoy the extra ponies....
I own 2 07's one with and one without. Riding beside my brother we are dead even till we hit 10k-11k rpms then ill just walk away from him. He is also 15lbs lighter than I am.
RMSZX6R is offline   Reply With Quote
Old 05-16-2007, 12:21 AM   #5 (permalink)
Kawi Supporter
ziyue is around zero rep points
I took my seat off the other day to just look for this connector. I think I found it, but it's ziptied to parts of the bike. Is that true for you or? My looks kinda gray.
ziyue is offline   Reply With Quote
Old 05-16-2007, 12:42 AM   #6 (permalink)
phobos512's Avatar
phobos512 has at least 1500 rep pointsphobos512 has at least 1500 rep pointsphobos512 has at least 1500 rep pointsphobos512 has at least 1500 rep pointsphobos512 has at least 1500 rep pointsphobos512 has at least 1500 rep pointsphobos512 has at least 1500 rep pointsphobos512 has at least 1500 rep pointsphobos512 has at least 1500 rep pointsphobos512 has at least 1500 rep pointsphobos512 has at least 1500 rep points
Send a message via Yahoo to phobos512
No it looks exactly like the pics in the link above - exactly.
phobos512 is offline   Reply With Quote
Old 05-16-2007, 01:00 AM   #7 (permalink)
RMSZX6R's Avatar
there will be 4 wires going to it and its capped. it doesn't plug into anything at all
Old 05-16-2007, 06:45 AM   #8 (permalink)
hextavo's Avatar
hextavo has at least 500 rep pointshextavo has at least 500 rep pointshextavo has at least 500 rep pointshextavo has at least 500 rep pointshextavo has at least 500 rep pointshextavo has at least 500 rep points
I got a question, anyone know where you can get one of the actual wires for this jumper?? I wanna replace my crappy wire with the real deal!? I know a guy on the forums has them and will ship em to you for a small price or free, but I don't remember who...?
hextavo is offline   Reply With Quote
Old 05-16-2007, 07:21 AM   #9 (permalink)
636cc of fury is around zero rep points
Send a message via AIM to 636cc of fury
I am using an insulated paper clip. The ends have no insulation and the mod works as I have proven it with a dyno.
636cc of fury is offline   Reply With Quote
Old 05-16-2007, 08:16 AM   #10 (permalink)
KingKash420's Avatar
KingKash420 is around zero rep points
Send a message via AIM to KingKash420
I am going to be doing this mod as soon as my bike gets it's first service.. thanks for the write up!
KingKash420 is offline   Reply With Quote
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
