I couldn't find anything on it so my buddy and I made one($110...fuck that). It took me a couple weeks with whatever spare time I had to make but it's finished. You can use just about any small diode where it is written diode in my shitty ms paint drawing (I found a spare diode with numbers i couldn't read; tested it, used it and it works fine). 390 is 1% 470k is 5% 75k is 1% Cap is 10%. I just cut off the connectors on the motor and reused them. Thanks to Adam for the help.
2009 ZX6R ME / PCV / Autotune / Akrapovic EVO open / Comp Werks FE / Self made exh servo motor eliminator / Air induction removal kit / Zero gravity DB / Ohlins steering damper / Ohlins shock. Waiting for some spare time to install -1+2 sprockets, DID chain, speedo healer and X-tre.
Uh oh, you caught me i'm not an EE nor is my friend but we still made one so chill. It's a line schematic. Hook up everything to this (LM3900N) I used number 2's. I'm sure you guys can figure out which wires to hook up. There are only 5 and i broke them up on the drawing. Two for the small connector and three for the big connector. Forgot to write that down on our our drawing when we hooked it up. I just don't wanna go to the underground parking to uncover the bike and remove the seat, I'm lazy.
Ok, that makes a lot more sense now. I took the liberty of drawing up a new schematic.
