Fairing removal on a 2009 ZX6R
Side panels (p.15-16)
Side panels can be popped out by hand in order to remove the front seat without completely removing the side panels.
To completely remove the panels, remove the front bolt and pull straight out.
Front seat (p.15-8)
After popping out the rear of the side panels or removing them completely, remove the two bolts holding the seat on. (one per side)
Lift front of seat up and remove.
Rear seat (p.15-8)
Insert ignition key into seat lock and turn to disengage the seat latch.
Pull up on the front of the seat to remove.
Lower fairings (p.15-9)
Remove the three bolts at the front and one at the rear.
Pry out center of lower front pop rivet and remove the small pop rivet joining the lower fairing to the lower center fairing.
Separate top clips from center fairing.
Repeat on other side.
Lower inner fairing (p.15-9)
Separate top of fairing from rubber grommet on radiator.
Separate sides of fairing from center fairings making sure not to loose the rubber nuts.
Upper inner fairings (p.15-13)
Remove the two pop rivets and front and rear bolts
Separate top of fairing from the rubber nut attached to the windshield
Clear rear projections from the frame.
Windshield (p.15-23)
Remove remaining bolts from windshield
Lift up and slide it off.
. . . Continued . . .
