Fairing removal on a 2009 ZX6R
Side panels (p.15-16)
• Side panels can be popped out by hand in order to remove the front seat without completely removing the side panels.
• To completely remove the panels, remove the front bolt and pull straight out.
Front seat (p.15-8)
• After popping out the rear of the side panels or removing them completely, remove the two bolts holding the seat on. (one per side)
• Lift front of seat up and remove.
Rear seat (p.15-8)
• Insert ignition key into seat lock and turn to disengage the seat latch.
• Pull up on the front of the seat to remove.
Lower fairings (p.15-9)
• Remove the three bolts at the front and one at the rear.
• Pry out center of lower front pop rivet and remove the small pop rivet joining the lower fairing to the lower center fairing.
• Separate top clips from center fairing.
• Repeat on other side.
Lower inner fairing (p.15-9)
• Separate top of fairing from rubber grommet on radiator.
• Separate sides of fairing from center fairings making sure not to loose the rubber nuts.
Upper inner fairings (p.15-13)
• Remove the two pop rivets and front and rear bolts
• Separate top of fairing from the rubber nut attached to the windshield
• Clear rear projections from the frame.
Windshield (p.15-23)
• Remove remaining bolts from windshield
• Lift up and slide it off.
. . . Continued . . .
Front seat (p.15-8)
Rear seat (p.15-8)
