2009 ZX6R Oil Change : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 12-03-2009, 04:52 PM   #1 (permalink)
Thrash1982 has between 5,000 and 7,500 rep pointsThrash1982 has between 5,000 and 7,500 rep pointsThrash1982 has between 5,000 and 7,500 rep pointsThrash1982 has between 5,000 and 7,500 rep pointsThrash1982 has between 5,000 and 7,500 rep pointsThrash1982 has between 5,000 and 7,500 rep pointsThrash1982 has between 5,000 and 7,500 rep pointsThrash1982 has between 5,000 and 7,500 rep pointsThrash1982 has between 5,000 and 7,500 rep pointsThrash1982 has between 5,000 and 7,500 rep pointsThrash1982 has between 5,000 and 7,500 rep points
Default 09 ZX6R Oil Change
Changing oil on a 2009 ZX6R
• First of all, changing the oil can be done without completely removing the fairings. I just happened to have them all off for a tutorial I put together on how to take them off. While it can be done, having them off does make it easier.
• Remove the lower fairings. (reference http://www.kawiforums.com/2009-zx-6r...-tutorial.html if needed)
• Let the bike warm up for a few minutes to thin the oil out and make it drain easier.
• Place a pan under the drain plug. (be sure to open the drain plug and vent in the pan if it is like mine, ask me how I know)
• Loosen the oil filler cap (leave it on) and remove the drain plug with a 17mm socket. I like to wear nitrile or latex gloves to make cleanup a bit easier.
• Let oil drain for a few minutes.
• The positioning of the oil filter is pretty awkward and likes to drip oil all over the side of your engine. I tried to make a little shield out of aluminum foil but it didn’t help much. If anybody has any suggestions on how to keep things clean I’m all ears.
• Remove the oil filter. (unfortunately there aren’t many pictures after this step as the process got pretty messy)
• Fill the new oil filter with oil and put some oil on the o-ring.
• Replace the washer on the drain plug with a new one, reinstall and torque to 21 ft/lb.
• Install new oil filter torquing it to 13 ft/lb.
• Remove oil filler cap and add oil.
• The engine will require 3.1 L of oil with a filter change (including the oil you poured into the filter) or 2.8 L if filter is not removed.
• Fill until you see oil between the two marks in the sight glass.
• Run the bike for a minute or three (make sure the oil icon on the LCD turns off after a few seconds, if it doesn’t you may have a problem) to let the oil circulate through the engine and filter.
• Turn the bike off and let the oil drain back into the oil pan. This will take a few minutes.
• Check the sight glass again and add oil until the oil level comes up between the two indicator lines again. (see previous pic)
And for your convenience, a .pdf copy of the above.
RapidShare: 1-CLICK Web hosting - Easy Filehosting
Thrash1982 is offline   Reply With Quote
Old 12-03-2009, 05:20 PM   #2 (permalink)
noidest04 has at least 250 rep pointsnoidest04 has at least 250 rep pointsnoidest04 has at least 250 rep pointsnoidest04 has at least 250 rep pointsnoidest04 has at least 250 rep points
Thrash thanks for the write up! Every time I do maintenance/mod I always say I will do a write up and it neeever happens. My "shield" is a paper bag.
Originally Posted by JustAJ View Post
If your fender eliminator comes with a little motor and some hinges and they see it, you're screwed.
noidest04 is offline   Reply With Quote
Old 12-03-2009, 06:01 PM   #3 (permalink)
exalted512's Avatar
What is everyone using for oil and filters?
-Cody
2009 650R (Street)--Stock
Old 12-03-2009, 06:07 PM   #4 (permalink)
I use K&N. Love the design of the housing. They included a 17mm hex on the top so you can get a socket wrench on it and not have to use a filter wrench. Makes it much easier, especially in such a tight space.
For oil I've been using Spectro. Just drained the Spectro Gold semi-synthetic and put in Spectro Platinum full synthetic
Old 12-03-2009, 08:32 PM   #5 (permalink)
greenspirit6r's Avatar
greenspirit6r has at least 500 rep pointsgreenspirit6r has at least 500 rep pointsgreenspirit6r has at least 500 rep pointsgreenspirit6r has at least 500 rep pointsgreenspirit6r has at least 500 rep pointsgreenspirit6r has at least 500 rep points
With the filter being horizontal, doesnt that make it kinda tricky to prime the filter?
And shepherds we shall be, For Thee, my Lord, for Thee. Power hath descended forth from Thy hand, That our feet may swiftly carry out Thy command. So we shall flow a river forth to Thee And teeming with souls shall it ever be. In nomine Patris et Filii et Spiritus Sancti. The Boondock Saints
greenspirit6r is offline   Reply With Quote
Old 12-03-2009, 08:37 PM   #6 (permalink)
Just fill it about halfway with oil first. Mostly it just makes it tricky to change without making a mess. I've heard of people having to burp the filter after installing it because the pressure sensor isn't registering the oil. So you'd have to run the bike, unscrew the filter a bit until oil sprays out then tighten it back up. I didn't have any issues. Filled the filter, screwed it in (quickly!), filled the sump and started it up. Oil icon went off after about 3 or 4 seconds.
Old 12-04-2009, 06:01 AM   #7 (permalink)
lunaticrider's Avatar
lunaticrider has between 10,000 and 20,000 rep pointslunaticrider has between 10,000 and 20,000 rep pointslunaticrider has between 10,000 and 20,000 rep pointslunaticrider has between 10,000 and 20,000 rep pointslunaticrider has between 10,000 and 20,000 rep pointslunaticrider has between 10,000 and 20,000 rep pointslunaticrider has between 10,000 and 20,000 rep pointslunaticrider has between 10,000 and 20,000 rep pointslunaticrider has between 10,000 and 20,000 rep pointslunaticrider has between 10,000 and 20,000 rep pointslunaticrider has between 10,000 and 20,000 rep points
-Cody
Amsoil nano fiber EaOM103 filter and Amsoil 10w40 synthetic.
If Racing Was Outlawed ..... Then Only Outlaws Would Race .....
Homeade bike worktable -http://www.kawiforums.com/two-wheele...bike-lift.html
lunaticrider is offline   Reply With Quote
Old 12-04-2009, 08:32 AM   #8 (permalink)
markiepoo6785 has at least 500 rep pointsmarkiepoo6785 has at least 500 rep pointsmarkiepoo6785 has at least 500 rep pointsmarkiepoo6785 has at least 500 rep pointsmarkiepoo6785 has at least 500 rep pointsmarkiepoo6785 has at least 500 rep points
Another typically super easy job made difficult by the kawasaki designers.
The horizontal oil filter makes it a messy job.
I use K&N oil filter. They have a nut welded on the top, which makes it easy to torque or remove the filter.
Nice write. Should be a sticky for us 09 zx6r riders.
2009 Kawasaki ZX-6R GREEN
MODS: Yoshimura Full Exhaust / Power Commander V / Auto Tune Kit / X-TRE Power Box / Driven Sprocket -1+2 / Speedohealer / Rear Cowl / Pazzo Levers / Jumper Mod / Ivan's Servo Eliminator / Ivan's Air Induction Removal Kit / Clear Alternatives Integrated Tail Light / Evotech No-Cut Frame Sliders / Homemade Fender Eliminator / Team Kawasaki Tank Protector
markiepoo6785 is offline   Reply With Quote
Old 12-04-2009, 01:45 PM   #9 (permalink)
Overwhelming Splendidery
slev's Avatar
slev has at least 80,000 rep pointsslev has at least 80,000 rep pointsslev has at least 80,000 rep pointsslev has at least 80,000 rep pointsslev has at least 80,000 rep pointsslev has at least 80,000 rep pointsslev has at least 80,000 rep pointsslev has at least 80,000 rep pointsslev has at least 80,000 rep pointsslev has at least 80,000 rep pointsslev has at least 80,000 rep points
Good deal, thanks. Horizontal filter is fucking brutal.
.: Titanium 2005 636 .:. Orange 2009 ZX6R (stolen) .:. Black 2009 250R :.
slev is offline   Reply With Quote
Old 12-04-2009, 05:36 PM   #10 (permalink)
Oh, I forgot to mention. It is a good idea to remove any watches, bracelets, rings or any other hand mounted jewelery before unscrewing and removing the drain plug. That oil really shoots out of there.
