How-To : Install an M4 GP Slip-On Exhaust on 09/10 ZX6R : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 05-11-2010, 10:30 PM   #1 (permalink)
haksu's Avatar
haksu has at least 250 rep pointshaksu has at least 250 rep pointshaksu has at least 250 rep pointshaksu has at least 250 rep pointshaksu has at least 250 rep points
Default How-To : Install an M4 GP Slip-On Exhaust on 09/10 ZX6R
Hello.
So I bought my 2010 ZX6R in White in Australia a month ago and just wrapped up the break in period. So I went ahead and ordered myself an M4 GP Slip-On exhaust from MotoMummy and 5 days later it was at my doorstep.
I've photographed/documented the install to the best of my ability.
Tools You Will Need:
Allen Keys - I suggest you get some T-Bar Allens for leverage as some of those bolts are recessed quite far back and you will need alot of torque to undo them
Socket Wrenches - I did it without socket wrenches and trust me... I would not reccommend it
Normal Wrenches - You need some plain wrenches to hold onto the backside of a nut while tightening or loosening, important for attaching the bracket inside the frame behind the rearset
Workshop Gloves (Optional) - There is alot of stuff to nick your hands on underneath the bike
Phase 1: Stock Exhaust Removal
You need to remove the 3 bolts holding the end cap onto the canister
Put the parts aside in a safe location
You will be left with a bare looking back end
Remove the housing at the other end of the canister, there are two bolts to remove
Remove the sheath and place somewhere safe.
This is your new task
We need to remove the butterfly valve cables controlled by the servo underneath the seat.
Take a wrench and loosen the nut at the slots
Tuck the cables away for now, we will remove them later.
Now duck underneath the bike for a moment and look for where the canister is held to the pre-exhaust chamber and loosen the clamp nut.
Go ahead and loosen the mount to the rear footpeg as well
Remove the exhaust off the bike carefully and voila...
You will need to remove another bolt on the side on top of the chamber
As well as another two on the bottom
This part, I forgot to photograph (SORRY!)
You will need to loosen the clamp holding the chamber to the headers - this is almost impossible to do without a socket wrench... but I still did it. Please for your own sanity, use a socket wrench! If you haven't got any, get some!
I digress.
There are also two bolts that hold the chamber to the frame via a bracket.
You will need some small hands, or a T-Bar Allen key and heaps of torque, they are pretty tight.
After that, wiggle the chamber out.
You will need to wedge it against the back wheel, I found a small spin helped to dislodge it. Be patient with it and it'll come.
This is what you should end up with
Phase 2: M4 GP Exhaust & Bracket Install
You will now need to remove the right footpeg.
BE CAREFUL NOT TO APPLY TOO MUCH TORQUE OR YOU MAY STRIP THE HEAD!!!!!!!!! You have been warned... Those suckers are on there TIGHT
Place the bracket behind the rearset points and affix using the supplied nuts and bolts. You will need patience and a steady hand to keep the nut in the right place. The bolt should screw in nice and easily so don't stress
The below; if you look carefully you can see the bracket behind the rearset.
Now we are on the home straight!
Slide the slip-on into the header. Be careful not to damage the gasket too much, but you will need to apply some force, it's meant to be snug
Tighten up the bolt that holds the exhaust to the bracket (the one you just installed) making sure the exhaust mount tab is on the OUTSIDE edge of the bracket. Tighten it up and then tighten up the clamp holding the exhaust to the headers.
You've just installed the M4 GP Slip On Exhaust!
At this point, I removed the seat and removed the cables that are controlled by the servo motor.
In my excitement, I forgot to take photos there also - SORRY!
But it's very easy, you can then remove both cables entirely from the bike. Some people choose to leave them there, but it's easy enough to re-route incase you need to revert to stock.
I also removed my rear footpegs while I was there, just to clean the tail end up a touch.
Voila! Stand back, look at your handy work, turn on the bike, gasp for ear and cover your ears!
Thanks for reading! I hope this has been informative and useful to people apprehensive about the install.
2010 Kawasaki Ninja ZX6R - White
Akrapovic Slip-On, Carbon Fibre Front Fender, Pazzo Shorty Levers, F.Fabbri Windscreen, Venhill Braided Brake Lines, Brembo Front Brake Pads, Fender Eliminator, Oggy Knobs Frame Sliders, Fork and Swing arm Axle Armour, Solo Seat Cowl, Evotech Exhaust Hanger, 6000k HIDs and White LED Parking Lights, Pirelli Diablo Rosso Corsa
haksu is offline   Reply With Quote
Old 05-11-2010, 10:56 PM   #2 (permalink)
evoalex's Avatar
evoalex has at least 4000 rep pointsevoalex has at least 4000 rep pointsevoalex has at least 4000 rep pointsevoalex has at least 4000 rep pointsevoalex has at least 4000 rep pointsevoalex has at least 4000 rep pointsevoalex has at least 4000 rep pointsevoalex has at least 4000 rep pointsevoalex has at least 4000 rep pointsevoalex has at least 4000 rep pointsevoalex has at least 4000 rep points
nice write up
2009 ZX6R Black - | M4 GP slip on | B2 Industries race rails | SS fender eliminator | DDM 55W 6K HID's | DMP LED integrated taillight | Amber LED running lights | Shogun spools | Go Pro HD |
Youtube Channel #1 (indecl1ne) Youtube Channel #2 (WTFilmProductions)
evoalex is offline   Reply With Quote
Old 05-11-2010, 11:35 PM   #3 (permalink)
NYDiplomat's Avatar
NYDiplomat has at least 2000 rep pointsNYDiplomat has at least 2000 rep pointsNYDiplomat has at least 2000 rep pointsNYDiplomat has at least 2000 rep pointsNYDiplomat has at least 2000 rep pointsNYDiplomat has at least 2000 rep pointsNYDiplomat has at least 2000 rep pointsNYDiplomat has at least 2000 rep pointsNYDiplomat has at least 2000 rep pointsNYDiplomat has at least 2000 rep pointsNYDiplomat has at least 2000 rep points
Thank you. This should shut some people up. (No offense to them) Great write up.
Blue '09 ZX-6r - Shogun Crash Kit, Rear Cowl, eBay Fender Eliminator, M4 GP Slip-on, Real Ohlins SD, Spiegler Brakeline F&R, PCV, K&N Air filter, X-TRE, ASV C/5
WishList: ZG Corsa
NYDiplomat is offline   Reply With Quote
Old 05-12-2010, 07:48 AM   #4 (permalink)
Penthos's Avatar
Penthos has at least 3000 rep pointsPenthos has at least 3000 rep pointsPenthos has at least 3000 rep pointsPenthos has at least 3000 rep pointsPenthos has at least 3000 rep pointsPenthos has at least 3000 rep pointsPenthos has at least 3000 rep pointsPenthos has at least 3000 rep pointsPenthos has at least 3000 rep pointsPenthos has at least 3000 rep pointsPenthos has at least 3000 rep points
Originally Posted by evoalex View Post
nice write up
+1
+1
It will only quiet those who actually use the search function .
'09 ZX6R Kawi green. miles: 28,861 so far. Mods: M4 GP slip-on, Spiegler SS brake lines f/r, Carbon Lorraine brake pads (f) XBK5 (r) RX3, LSL frame sliders, CRG rC levers brake/clutch, Ohlins steering damper upgrade by LAKO Performance Group, Pitbull spools, StompGrips, SATO Racing rearsets - oil cap - race hooks, Zero Gravity Corsa smoked windscreen, Kawasaki Solo Seat Cowl & custom fender eliminator.
Penthos is offline   Reply With Quote
Old 05-12-2010, 10:42 AM   #5 (permalink)
dpitti06's Avatar
dpitti06 has at least 10 rep points
Great write up...i'm extremely jealous of the white, i wish they had that available her in the US.
09' ZX6R ME - Mods: Clear Alternatives Integrated LED tail light / Vortex Spools / Shogun No-Cut Sliders / Pazzo Shorty Levers / M4 Slip on / Bazazz ZF-I / Driven -1, +2 / SpeedoDRD / Hotbodies DB
dpitti06 is offline   Reply With Quote
Old 05-12-2010, 10:48 AM   #6 (permalink)
matt69's Avatar
matt69 has at least 250 rep pointsmatt69 has at least 250 rep pointsmatt69 has at least 250 rep pointsmatt69 has at least 250 rep points
Thanks for the write up! I am going to do the insta today with this in hand. Rep 2 u!
matt69 is offline   Reply With Quote
Old 05-12-2010, 11:14 AM   #7 (permalink)
Sic22's Avatar
Sic22 has at least 50 rep pointsSic22 has at least 50 rep points
Excellent write up! I'll also be installing mine tonight with this in hand! After seeing your bike in white..painting my bike is now a possibility! Thanks Again!
09' ZX6R Kawi Green (Current Bike)
05' ZX6RR Kawi Green (Unfortunately Sold)
Sic22 is offline   Reply With Quote
Old 05-12-2010, 11:17 AM   #8 (permalink)
Sic22's Avatar
Any difference on the install between the zx10 and zx6?
Old 05-12-2010, 06:52 PM   #9 (permalink)
haksu's Avatar
Thanks all for your kind comments.
I hope it helps guys
Old 05-12-2010, 08:33 PM   #10 (permalink)
Sic22's Avatar
Helped A LOT!! Just installed the exhaust and it looks and sounds awesome! Only took about 30 minutes thanks to this post!
