2012 header replacement : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-10-2012, 09:18 AM   #1 (permalink)
peterj59 has at least 10 rep points
Question 2012 header replacement
Just purchased a header from MJS to get rid of the cat converter on my 2012 zx6R,
the manual calls for remvoing the radiator, my question is it possible to remove and replace the header without removing the radiator????
Has anyone have experience with this install???
peterj59 is offline   Reply With Quote
Old 11-10-2012, 04:54 PM   #2 (permalink)
Hooligan
-knucklehead- has between 10,000 and 20,000 rep points-knucklehead- has between 10,000 and 20,000 rep points-knucklehead- has between 10,000 and 20,000 rep points-knucklehead- has between 10,000 and 20,000 rep points-knucklehead- has between 10,000 and 20,000 rep points-knucklehead- has between 10,000 and 20,000 rep points-knucklehead- has between 10,000 and 20,000 rep points-knucklehead- has between 10,000 and 20,000 rep points-knucklehead- has between 10,000 and 20,000 rep points-knucklehead- has between 10,000 and 20,000 rep points-knucklehead- has between 10,000 and 20,000 rep points
Try it n let us know
You'd only have to remove it for clearance- when I replaced mine with ARROW headers- I never did(take off rad)
And sorry but you got ripped off, a hammer and screw driver
Or drill, you coulda removed your own cat in 10 min
and painted it high heat black yourself
-knucklehead- is offline   Reply With Quote
Old 11-10-2012, 05:02 PM   #3 (permalink)
TJ Beavers
goingtoscotland's Avatar
Possibly. You'll have to remove the radiator mounting fasteners and try to move it out of the way enough to get the old headers out and new one in.
Old 11-10-2012, 06:16 PM   #4 (permalink)
livefast's Avatar
livefast has at least 50 rep pointslivefast has at least 50 rep pointslivefast has at least 50 rep points
I ended up removing both lower fairings, and just disconnected the lower radiator mounting bracket to swing the rad back a bit. I had to use an assortment of wrenches , ratchets and adapters to get to the tricky areas but It can be done though.
09' Monster Energy Zx6r-Akrapovic Evolution w/titanium headers and carbon fiber muffler, PCV, ASV C/5 shorty levers, Vortex clip ons, bikelitez Fe customized, clear alt. integrated taillight.
livefast is offline   Reply With Quote
Old 11-11-2012, 10:22 AM   #5 (permalink)
J_Fuggin_T's Avatar
Location: Northwest, Indiana 2009 Kawi ZX6r (track only)
J_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep points
You can but it makes 3 times the work.. Drain the radiator and refill it will save you a lot of cussing.
Mod list: Ohlins 30mm frnt cartrige kit / JRi piggyback triple shock / Brembo RCS / galfer superbike lines / pf 07 pads / Leo Vince sbk corsa Ti full exhaust / Stock revalved ohlins damper / Armor Bodies / Servobuddy / Skutr.net captive spacers / Vortex Rearsets / Bazzaz FI/QS/TC / Motion pro revolver / XT gpx / kit clutch mod /
J_Fuggin_T is offline   Reply With Quote
