Wobbly gas tank - Page 2 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-15-2012, 07:24 AM   #11 (permalink)
Jkruszelnicki's Avatar
Jkruszelnicki has at least 50 rep pointsJkruszelnicki has at least 50 rep pointsJkruszelnicki has at least 50 rep points
huh... See the issue I have is that both pieces are there, but they are not touching the gas tank. The gap between the tank and the frame is larger than the rubber tabs.
Jkruszelnicki is offline   Reply With Quote
Old 11-15-2012, 07:42 AM   #12 (permalink)
snx
snx's Avatar
snx has at least 250 rep pointssnx has at least 250 rep pointssnx has at least 250 rep pointssnx has at least 250 rep points
Then you have a slight problem. On my bike (2012) the rubber tabs are tightly fit into the gap. Without them my tank will wobble slightly. With them on, no movement.
Maybe you have something on your airbox that is preventing the tank to sit properly?
snx is offline   Reply With Quote
Old 11-15-2012, 09:49 AM   #13 (permalink)
That is what I am thinking... The airbox might be installed incorrectly and sitting too high. I am about to take it off and put it back. Hopefully that is what is wrong with it.
Old 11-15-2012, 12:13 PM   #14 (permalink)
So I took the airbox off and put it on again. Nothing has changed. Unless I am putting it on incorrectly somehow, I am really out of ideas.
Old 11-15-2012, 06:25 PM   #15 (permalink)
livefast's Avatar
livefast has at least 50 rep pointslivefast has at least 50 rep pointslivefast has at least 50 rep points
Have you made sure your clutch and throttle cables were run properly under the bracket that secures the stabilizer and tank down? You may not have that bracket seated correctly which would in turn prop up the tank a bit. Good luck.
09' Monster Energy Zx6r-Akrapovic Evolution w/titanium headers and carbon fiber muffler, PCV, ASV C/5 shorty levers, Vortex clip ons, bikelitez Fe customized, clear alt. integrated taillight.
livefast is offline   Reply With Quote
Old 11-15-2012, 06:39 PM   #16 (permalink)
ZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep points
Yep, probably cables! Make sure you've pressed the airbox down soh the velocity stacks sit flush before you tighten everything up.
ZX6-OZ is offline   Reply With Quote
Old 11-16-2012, 07:21 AM   #17 (permalink)
Great idea! I will check it out today!
Old 11-18-2012, 09:29 PM   #18 (permalink)
J_Fuggin_T's Avatar
Location: Northwest, Indiana 2009 Kawi ZX6r (track only)
J_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep points
My tank rocks side to side as well, it's supposed to so it doesn't absorb so much vibration. The black side panels as listed above create a spacer and stop it for the most part.
Mod list: Ohlins 30mm frnt cartrige kit, Ohlins TTX rear shock, Brembo RCS master w/ galfer superbike lines & performance friction pads, M4 gp s/o, Stock revalved ohlins damper, Armor Bodies, -1/+2 gearing, Servobuddy servo eliminator, Servobuddy captive spacers, Vortex Rearsets, Bazzaz FI/QS
J_Fuggin_T is offline   Reply With Quote
Old 11-19-2012, 06:55 AM   #19 (permalink)
I'd have to check mine again but the bike is in the garage under a pile of crap and will remain there for a while... but I THINK the tank doesn't move any more. Or if it does, it's very little.
Old 11-19-2012, 01:26 PM   #20 (permalink)
snx
snx's Avatar
As I said, it doesn't move at all. I just rode it today and it is solid with the side covers on. However it could be that my bike is new. It is 6 months old now.
