Kit ECU questions : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-29-2012, 07:23 PM   #1 (permalink)
daytona155 has at least 500 rep pointsdaytona155 has at least 500 rep pointsdaytona155 has at least 500 rep pointsdaytona155 has at least 500 rep pointsdaytona155 has at least 500 rep pointsdaytona155 has at least 500 rep pointsdaytona155 has at least 500 rep points
Default Kit ECU questions
I found a great deal locally for the following however I have a question before pulling the trigger
Kit ECU
Kit Harness
Power Commander 5
Quickshifter
This is all coming off a race bike being parted out. My only concern however is with the extra 750 rpm will this kill my engine? The package really is a screaming deal and will simplify my wiring and give me a quickshifter, however I'm not looking for major engine mods. It DOES NOT come with the tuning cable as well so being in North Virginia (Manassas area) will there be any place to get it tuned for a reasonable amount of money?
Thank you in advance,
Mike
daytona155 is offline   Reply With Quote
Old 11-29-2012, 07:25 PM   #2 (permalink)
I should also mention this is on a strictly track only bike, not trying to take this to the street (obvious with the harness just thought I'd clear that up)
Old 11-29-2012, 07:28 PM   #3 (permalink)
Powerhungry
nevada's Avatar
im pretty sure you can adjust the limiter.
and, with the kit ECU, you shuldnt need the pc. thats redundant.
Old 11-29-2012, 07:45 PM   #4 (permalink)
Without the cable however is it still possible to adjust the limiter? I don't really want to shell out another $600 for the cable.
Yeah it's redundant however it's the entire setup off of another bike so unless I get it tuned it would be an easy plug and play setup.
Old 11-29-2012, 08:51 PM   #5 (permalink)
Powerhungry
nevada's Avatar
no, you wouldnt be able to adjust anything.
sell the PCV, and buy a cable.
and, if you find a tuner that has the cable, you're set. and still wont need the pcv...
on the other hand, without the cable/tuner, the kit ecu is crap.
Old 11-29-2012, 10:33 PM   #6 (permalink)
ZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep pointsZX6-OZ has at least 1500 rep points
↑↑↑↑This!
Sell the PC (and quickshifter if it's the dynojet model - get an Anitori instead, worth it) and have the bike properly tuned at a dyno. Otherwise, pointless... you can adjust the rev limiter and play with a bunch of other settings and etc but if you don't have the ECU tuned to your bike/engine it makes no sense to buy it in the first place.
If you need the cable anyway, there's a guy on zx10r.net that sells a generic version of it for much less... just look him up.
ZX6-OZ is offline   Reply With Quote
Old 11-30-2012, 10:54 AM   #7 (permalink)
This generic cable, I remember seeing it before but wasn't it for an older 1st gen zx10? Has it been proven that it works with an 09+ zx6r kit ecu?
Also does anybody know of a reputable tuner in the North Virginia/DC area (or 200ish miles around that area)?
Old 11-30-2012, 02:12 PM   #8 (permalink)
BikeAholic
jdgun_13's Avatar
jdgun_13 has between 40,000 and 50,000 rep pointsjdgun_13 has between 40,000 and 50,000 rep pointsjdgun_13 has between 40,000 and 50,000 rep pointsjdgun_13 has between 40,000 and 50,000 rep pointsjdgun_13 has between 40,000 and 50,000 rep pointsjdgun_13 has between 40,000 and 50,000 rep pointsjdgun_13 has between 40,000 and 50,000 rep pointsjdgun_13 has between 40,000 and 50,000 rep pointsjdgun_13 has between 40,000 and 50,000 rep pointsjdgun_13 has between 40,000 and 50,000 rep pointsjdgun_13 has between 40,000 and 50,000 rep points
Buy it and run it...
And there is various arguements for running the add on fueler, QuickShifter, Easy Fueling changes, Autotune, availability of tuners.
If you have the money to pay a Tuner the KIT ECU by itself can truly make that power where a PCV or bazzaz cant (it won't be a 2 hour tune like the other systems)..
But with the base kit ecu tune, adjusted rev limit, ignition timing alone you will be gainging power over someone who does not have the same options.
I am a KIT ECU with a piggyback PCIII (sson to be bazzaz Z-fi/tc/qs) user.
2004 ZX10R (Trickstar bodywork anyone?)
2005 ZX6R Raw Ti-Pleasure
http://www.superstreetbike.com/custo..._6r/index.html
2006 675 Daytona
2007 1098 Ducati
jdgun_13 is offline   Reply With Quote
Old 11-30-2012, 02:32 PM   #9 (permalink)
exalted512's Avatar
Not sure how good of a deal you're getting, but there's this one as well. Tell him I sent you.
Parting out 2009 zx6 fully built ohlins, traxxion, kit ecu, vortex : Kawasaki ZX Forums: Kawasaki Ninja Forum
-Cody
2009 650R (Street)--Stock
