PCV and QEM : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-30-2012, 08:03 PM   #1 (permalink)
nk140 has at least 10 rep points
Default PCV and QEM
What are the settings that everyone is using for their PCV and quick shifter. Mine is acting funny. Like I have to double tap the shifter to get it to go into the next gear. It seems the PCV is killing fuel after I release the shifter.
Specifically what type of sensor are you using "Normally Open" or "Normally Closed"? Also what are your kill times?
nk140 is offline   Reply With Quote
Old 12-02-2012, 09:45 PM   #2 (permalink)
Savior Six's Avatar
Savior Six has at least 250 rep pointsSavior Six has at least 250 rep pointsSavior Six has at least 250 rep pointsSavior Six has at least 250 rep pointsSavior Six has at least 250 rep points
If I remember correctly, here are my settings
Mode - Single
Switch Type - Normally Closed
Minimum RPM - 3000
Shift interval - 250
Kill Time all shifts - 65.00
Savior Six is offline   Reply With Quote
Old 12-03-2012, 08:12 AM   #3 (permalink)
Mode - Single
Minimum RPM - 3000
Well that sucks. I have been on the phone with PC three times now and my settings are set very similar to yours.
I was finally able to pin point the problem. The QEM registers the initial press of the lever but the PCV and QEM will not kill fuel until the lever is released. I know the switch is "Normally Closed" because the QEM and PCV will not register a shift with it in the "Normally Open" position.
I wonder if there is anyway to do a hard reset on both the PCV and QEM?
Old 12-03-2012, 09:42 AM   #4 (permalink)
snx
snx's Avatar
snx has at least 250 rep pointssnx has at least 250 rep pointssnx has at least 250 rep pointssnx has at least 250 rep points
I thought normally open or normally closed depends on which shift pattern you are running?
snx is offline   Reply With Quote
Old 12-03-2012, 01:08 PM   #5 (permalink)
Nope...PC started using Normally Closed switches with their PCV. I believe they used Normally Open on their PCIII switches. I could be mistaken, but that is what I have found during my endless research on my problem.
Old 12-07-2012, 06:39 PM   #6 (permalink)
Site Sponsor
DynojetResearch has at least 500 rep pointsDynojetResearch has at least 500 rep pointsDynojetResearch has at least 500 rep pointsDynojetResearch has at least 500 rep pointsDynojetResearch has at least 500 rep pointsDynojetResearch has at least 500 rep points
Did you figure this out yet. We changed the QEM last year and they now are looking for a NORMALLY OPEN style sensor. YOu can send a pic of the QEM to me and I can verify which one you have and we can also test the sensor to see which one you have. dusty@dynojet.com
DynojetResearch is offline   Reply With Quote
