81 KZ650 CSR issue - KawiForums - Kawasaki Motorcycle Forums
post #1 of 7 (permalink) Old 05-01-2011, 03:51 PM Thread Starter
81 KZ650 CSR issue
I have an 81 kz 650 csr and the issue I am having is that it seems to hit a flat spot at 5000 rpms. Once you get into the higher rpms the bike runs like a champ. I checked the carbs and everything looked fine. Anyone have issues with this before?
bleis716 is offline
post #2 of 7 (permalink) Old 05-01-2011, 07:30 PM
Loudviking's Avatar
Clean the carb's even if they look good. Rebuild kit may be a good idea also.
Any aftermarket accessory on it?
84 Kawa 750 Turbo
15 psi, Bov and other stuff
HANG ON
May 2011 BOTM WINNER
Loudviking is offline
post #3 of 7 (permalink) Old 05-02-2011, 05:09 AM Thread Starter
aftermarket ignition coils
bleis716 is offline
post #4 of 7 (permalink) Old 05-02-2011, 08:18 AM
Loudviking's Avatar
What brand and color.
84 Kawa 750 Turbo
HANG ON
post #5 of 7 (permalink) Old 05-05-2011, 08:27 PM Thread Starter
dyna green
bleis716 is offline
post #6 of 7 (permalink) Old 05-05-2011, 11:57 PM
Loudviking's Avatar
I will have to check but I think the Dyna Green's are 3.0 ohm , My bike has problems
with Greens so I know most Turbo owners use Dyna Gray coils at 2.2 ohm. I could be wrong
but I'm thinking that the 900 cc and over use Dyna Green coils. Other than that may still
be a carb issue.
84 Kawa 750 Turbo
HANG ON
post #7 of 7 (permalink) Old 05-06-2011, 12:00 AM
KarlyDJ's Avatar
Reclean your carbs and make sure that the pilot jets are clear. They are tiny and hard to see through, a single strand of copper from a copper wire should be able to fit through, if it cant, is not clean!
2006 Ninja 650R - Custom White with Red Pearl - Stolen, Destroyed, Paid Out. Sad, sad end.
Originally Posted by Ahmad View Post
thats why I hate forums, punch of fags behind there screens.
KarlyDJ is offline
