1980 KZ550 won stay running : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Go Back   KawiForums - Kawasaki Motorcycle Forums > On-Road > Classics and Standards
Old 06-24-2011, 11:37 PM   #1 (permalink)
BrewCity_kidd has at least 10 rep points
Default 1980 KZ550 wont stay running
What's up forum, I have a 1980 KZ550a that I got from a buddy. The bike was sitting for a few years and hasn't been started. I changed the coils, starter solenoid, rectifier, battery and cleaned the carbs. When I spray a little starter fluid in the carbs it putt putts but then dies (no fuel I assume). I checked the float bowls and they do have fuel sitting in them. Not sure what's happening that the fuel isn't getting to the cylinders? Hopefully someone can help me out.
BrewCity_kidd is offline   Reply With Quote
Old 11-11-2012, 09:48 PM   #2 (permalink)
daremoe63 has at least 10 rep points
Check to see if the exhaust is blocked (sitting critters like to nest and horde food) this happened to my 1981 kz1000
daremoe63 is offline   Reply With Quote
Old 01-06-2013, 09:41 PM   #3 (permalink)
ice7891's Avatar
ice7891 has at least 10 rep points
what about replacing the spark plugs and plug wires..... are you getting any spark?
ice7891 is offline   Reply With Quote
Old 01-07-2013, 10:23 AM   #4 (permalink)
DesmoBro's Avatar
DesmoBro has at least 250 rep pointsDesmoBro has at least 250 rep pointsDesmoBro has at least 250 rep points
are the carbs filling up with gas? you may have a blockage at the petcock
CHECK OUT THE BUILD
http://www.kawiforums.com/classics-s...fish-bike.html
DesmoBro is offline   Reply With Quote
Old 01-08-2013, 09:15 PM   #5 (permalink)
cookiebug79's Avatar
do you have the air filter back together and installed?
