1985 ZX600A Shift Shaft Seal Replacement - KawiForums - Kawasaki Motorcycle Forums
post #1 of 1 (permalink) Old 09-26-2016, 08:17 PM Thread Starter
Hello All again. I have one question... I removed my shift shaft seal on the zx600 with a screw. It was leaking bad when I shift the bike into gear and neutral( previous owner may have damaged the hole the seal goes into.) I also damaged the hole even more when installing a new one. Is their any way to fix this, or, do I need to replace main sprocket cover?
All replies are welcomed. Thank you.
TD
T. Davis is offline
