Go Back   KawiForums - Kawasaki Motorcycle Forums > Super Sport > Drag Racing
Old 07-10-2009, 05:48 PM   #1 (permalink)
kawi9's Avatar
kawi9 has at least 500 rep pointskawi9 has at least 500 rep pointskawi9 has at least 500 rep pointskawi9 has at least 500 rep pointskawi9 has at least 500 rep pointskawi9 has at least 500 rep points
Default What is the best drag radial tire ?
I have a turbo bike and i would like to know, what is best drag radial tire ? Mickey Thompson ? Shinko ? Weight difference ? How many psi you run in the tire ? Speed rate ? Thanks
kawi9 is offline   Reply With Quote
Old 07-10-2009, 06:49 PM   #2 (permalink)
rotten_riceball's Avatar
rotten_riceball has at least 250 rep pointsrotten_riceball has at least 250 rep pointsrotten_riceball has at least 250 rep points
Personal I HATE the shinko, but i know many that swear by it. Im using the Metzler Drag Tech. (sponsor buys them for me). I love it, and I run about 12 psi. Note that it only comes in a 190, which sux. But he's switching me over to the Mickey Tompson drag radial for the next tire, cause they are ALOT cheaper.
9.92 @ 137 MPH ZX6R!!!!
2009 NHRA Division 7 Sacramento Raceway Track Champion
rotten_riceball is offline   Reply With Quote
Old 07-10-2009, 11:57 PM   #3 (permalink)
punksrfr's Avatar
punksrfr has at least 2000 rep pointspunksrfr has at least 2000 rep pointspunksrfr has at least 2000 rep pointspunksrfr has at least 2000 rep pointspunksrfr has at least 2000 rep pointspunksrfr has at least 2000 rep pointspunksrfr has at least 2000 rep pointspunksrfr has at least 2000 rep pointspunksrfr has at least 2000 rep pointspunksrfr has at least 2000 rep pointspunksrfr has at least 2000 rep points
Send a message via AIM to punksrfr
The Drag Tech is a very good tire, I personally have had very good luck with the Michelin Pilot Pilot Race 3 (PR3 soft) You'll have to find a vendor that deals with the road race crowd. You have to have a license to sell these.
For the big power bikes the M/T is the class standard but they have monopolized the market in Pro Street and similar street tire classes. Recently the Michelin Pilot One has been putting down some amazing numbers for a tire designed for road course racing. It went 7.27@199 with a 1.25 60ft, 3.26 330ft. Very impressive, I read that it has 1/4in more roll out then the M/T on a 6.75in.
NHRA Summit Drag Racing Division 2 Qualifier 2007-2008
AMA Dragbike S/ET Round Winner-World Finals
Orlando Bike Bash 2007- Finalist
2002 ZX6R- 10.333@129.7 / 6.561@106.7 Stock motor, stock jetting, factory head gasket in place... and now...
2002 ZX6R Turbo- At a grudge race near you!...
2006 GSXR 1000- 1.468 60ft at 61in w/ stock shock... she's coming along...
punksrfr is offline   Reply With Quote
Old 07-11-2009, 12:32 AM   #4 (permalink)
zx racer's Avatar
zx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep points
shinko is a very good tire, its a lil on the heavy side but alot of dragracers use them & for the money you can't beat em, also alot of big motor guys with turbos & nitrous have been in the 7's in the 1/4 with these tires
05 Kawasaki Ninja ZX-10R.
swb, pc3, filter, sec flies removed, pipe, lowered, front end strap, geared.
zx racer is offline   Reply With Quote
Old 07-13-2009, 11:07 PM   #5 (permalink)
kawi9's Avatar
Thanks everybody for the reply,
I made some tests with my extended swingarm (+6in) and i have some traction problem. I want try some 1/4 mile passe, but i think i will need a drag radial tire . Could you tell me what is the tire pressure for the track. Thanks
It's a little video for show my traction problem. After this test, i lowered the boost from 11 psi to 9,5 psi and the traction is ok.
ZX9R Turbo Extended Swingarm Test - Car Videos on StreetFire
Old 07-14-2009, 05:36 PM   #6 (permalink)
N.C.rider's Avatar
N.C.rider has at least 500 rep pointsN.C.rider has at least 500 rep pointsN.C.rider has at least 500 rep pointsN.C.rider has at least 500 rep pointsN.C.rider has at least 500 rep pointsN.C.rider has at least 500 rep pointsN.C.rider has at least 500 rep points
depends on your tire. i used to run a shink(not the u soft) i had to run 12-13lbs to get it to hook. if i were going to get the shinko it would be a u soft. now i have a mich. power race soft compound and i can run 20 lbs aslong as the track is half decent. my next tire will be the dragtec. have you adjusted the rear shock any, to get it to hook better?
N.C.rider is offline   Reply With Quote
