i started making up a new manifold, i had my bike turboed a few months ago and rode it around for a while but the exhaust manifold warped a bit and had a tiny leak and the inlet manifold also split and was leaking boost, and when i pulled it off i found alot of oil in the intake side piping....thought maybe the seals were bad of the scavenge pump wasnt upto pumping the oil....
but i had been thinking about it and i think the oil problem was because i didnt have a check valve so whateva oil was left in the motor would drain through the turbo and because the scavenge pump is off it just backs up was only about 2inchs of hose between the pump and turbo for the oil to back up in.....and the bike leans to the left when its parked so think thats why the oil was in the intake side of the piping, because it never blew any smoke on the exhaust side when riding....
so try no. 2
this time i am tryin to make the manifold a little better different flange that shouldnt warp and will give it some bracing and also try make it flow a little better then the last one, now i have some more skills should be better.
intake i will make it out of bit thicker alloy and actualy buy some decent alloy, last time i just used an old sign and it was weak as piss....
heres a pic of my old manifold and new one i started today
tryin to keep turbo roughly in the same position as before so can use same oil and water hoses and intake piping
