07 600 with a new setup : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Go Back   KawiForums - Kawasaki Motorcycle Forums > Super Sport > Keep it off the Streets! > Drag Racing
Old 05-23-2011, 06:15 PM   #1 (permalink)
poofbegone's Avatar
poofbegone has at least 500 rep pointspoofbegone has at least 500 rep pointspoofbegone has at least 500 rep pointspoofbegone has at least 500 rep pointspoofbegone has at least 500 rep pointspoofbegone has at least 500 rep pointspoofbegone has at least 500 rep pointspoofbegone has at least 500 rep points
Default 07 600 with a new setup
Finally stretched my turbo 600 and took a lil trip to the track. Its sitting at 64.5" wheel base and only running 4 lbs of boost. I also made my own version of a tiger tail to keep the rocks from flinging up and into my seat. I'm still foot shifting with no quick shifters and i had a full tank of gas from the gas station. It made a 9.55 on my first pass and then just got quicker as I added fuel untill the end of the night when I pulled a 9.28 @148. Gotta get the power rolling on the launch, the 60ft was a bit slow.
07 600 with a new setup-img_0241.jpg   07 600 with a new setup-img_0244.jpg   07 600 with a new setup-img_0248.jpg   07 600 with a new setup-img_0250.jpg   07 600 with a new setup-img_0254.jpg
poofbegone is offline   Reply With Quote
Old 05-23-2011, 08:26 PM   #2 (permalink)
Micron05rr's Avatar
Micron05rr has at least 2000 rep pointsMicron05rr has at least 2000 rep pointsMicron05rr has at least 2000 rep pointsMicron05rr has at least 2000 rep pointsMicron05rr has at least 2000 rep pointsMicron05rr has at least 2000 rep pointsMicron05rr has at least 2000 rep pointsMicron05rr has at least 2000 rep pointsMicron05rr has at least 2000 rep pointsMicron05rr has at least 2000 rep pointsMicron05rr has at least 2000 rep points
Beautiful Robert! I can't wait to see you run that bad boy in person my friend.
2005 ZX6RR - 1/4 mile - 10.49@130.17mph videohttp://www.youtube.com/watch?v=w_KQhDSCvQA
Micron Serpent Full System - BMC Race Filter - Kawasaki Race ECU - PC3- Dynojet Quickshifter -Thin Head Gasket - Denso Iridium Plugs - Chevron 93 Pump Gas -Redline 30wt Full Synthetic - Geared -1, +4 Renthal Ultralight - Short Wheelbase -
www.mpsracing.com
Micron05rr is offline   Reply With Quote
Old 05-24-2011, 12:33 AM   #3 (permalink)
punksrfr's Avatar
punksrfr has at least 3000 rep pointspunksrfr has at least 3000 rep pointspunksrfr has at least 3000 rep pointspunksrfr has at least 3000 rep pointspunksrfr has at least 3000 rep pointspunksrfr has at least 3000 rep pointspunksrfr has at least 3000 rep pointspunksrfr has at least 3000 rep pointspunksrfr has at least 3000 rep pointspunksrfr has at least 3000 rep pointspunksrfr has at least 3000 rep points
Send a message via AIM to punksrfr
Awesome deal man, she still has a ton left in her!
Kawzuki for life!!!
punksrfr is offline   Reply With Quote
Old 05-24-2011, 02:26 AM   #4 (permalink)
Auszx has at least 50 rep pointsAuszx has at least 50 rep points
Nice man!
Will be keen to see how quick you end up getting it down to.
Are you planning on going to a better clutch set up with the turbo?
Keep us posted how she goes.
Auszx is offline   Reply With Quote
Old 05-24-2011, 02:36 AM   #5 (permalink)
littleman has at least 2000 rep pointslittleman has at least 2000 rep pointslittleman has at least 2000 rep pointslittleman has at least 2000 rep pointslittleman has at least 2000 rep pointslittleman has at least 2000 rep pointslittleman has at least 2000 rep pointslittleman has at least 2000 rep pointslittleman has at least 2000 rep pointslittleman has at least 2000 rep pointslittleman has at least 2000 rep points
you need a lock up and you will be there good job
littleman is offline   Reply With Quote
Old 05-24-2011, 04:51 PM   #6 (permalink)
poofbegone's Avatar
Hi and Thanks guys. I haven't really kept you guys updated on the changes I've made to the bike. It's been on the street for a while now I just can't get to a track often enough and Gainsville made me leave the track for going 9's with out a license (wasted trip). This is only my third time to the track in the last three months. First time out it was stock wheel base and did nothing but wheelie. Secondtime I was having trouble making boost cause of a leak.
I hope the clutches hold up for a while but I have heavy duty springs one thick steel to raise the stack hieght for the bite and if it starts to slip I'm going to use the friction plates that are used on the top and bottom of the stack. The outside frictions have more contact area than the inner frictions. I calculated it out a lil while ago but I think it was about 15-20% more contact area per plate. You're rite tho Steve, a lock up would be the answer.
Old 05-24-2011, 11:51 PM   #7 (permalink)
kawiman1's Avatar
kawiman1 kawiman1 kawiman1 kawiman1 kawiman1 kawiman1
man that is sexy, who did the exhaust manifold and what turbo did u go with
kawiman1 is offline   Reply With Quote
Old 05-26-2011, 09:14 AM   #8 (permalink)
poofbegone's Avatar
I built the manifold and plenum. The turbo that is on there is a gt-15 but I'm going back to the gt-25.
Old 05-27-2011, 12:15 AM   #9 (permalink)
kawiman1's Avatar
man i wish i could see the set up alil closer, was it hard to make both, maybe some pics of both
Old 05-29-2011, 06:55 AM   #10 (permalink)
aussie_636 has at least 1000 rep pointsaussie_636 has at least 1000 rep pointsaussie_636 has at least 1000 rep pointsaussie_636 has at least 1000 rep pointsaussie_636 has at least 1000 rep pointsaussie_636 has at least 1000 rep pointsaussie_636 has at least 1000 rep pointsaussie_636 has at least 1000 rep pointsaussie_636 has at least 1000 rep points
is that pan stock? 636 one is gay, pick up hangs down way low. what rpm does the gt15 spool at? i had a t2, but t25 is a good size
aussie_636 is offline   Reply With Quote
