stretching bike : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Go Back   KawiForums - Kawasaki Motorcycle Forums > Super Sport > Keep it off the Streets! > Drag Racing
Old 11-28-2012, 04:38 AM   #1 (permalink)
kawiman1's Avatar
kawiman1 kawiman1 kawiman1 kawiman1 kawiman1 kawiman1
Default stretching bike
my 07 zx6r since adding the turbo is lowered but still lifting alot, i ordered the extended swingarms for it and see on other stretched bikes they lift up still, if i go 9 inches is that too much
kawiman1 is offline   Reply With Quote
Old 03-09-2013, 09:10 AM   #2 (permalink)
zx racer's Avatar
zx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep points
you should be fine with that much wb.
04 ZX-636.
zx racer is offline   Reply With Quote
Old 03-12-2013, 10:38 PM   #3 (permalink)
kawiman1's Avatar
had to give up on trying to get this turbo going. no help here on the west coast. changing pumps adding injectors fiddling with the fuel pressure. still the same problem. today was the last day of trying, i tried adding a boost controller and still stayed at 2pds with a 5 pd spring. Looks like back to n/a
Old 03-13-2013, 11:44 AM   #4 (permalink)
Alias's Avatar
Alias has at least 3000 rep pointsAlias has at least 3000 rep pointsAlias has at least 3000 rep pointsAlias has at least 3000 rep pointsAlias has at least 3000 rep pointsAlias has at least 3000 rep pointsAlias has at least 3000 rep pointsAlias has at least 3000 rep pointsAlias has at least 3000 rep pointsAlias has at least 3000 rep pointsAlias has at least 3000 rep points
Have you contacted any of the bigger shops that deal with turbos for help. Most are more than willing to help. If not, here are a few that I deal with that might be helpful:
Orient Express
Brocks Preformance
Schnitz Racing
They may be able to get you in the right direction and at least figure out the problems your having.
www.kmmotorcycleleathers.com - Arlen Ness, Teknic, ForceField, Racer Gloves, KNOX, Leatt, SCORPION EXO, Dainese, Alpinestars.
www.kmmotorcycleparts.com - Diablo Racing, Driven,Woodcraft,Bazzaz,Hotbodies,MWR, Armour Bodies, DM Meccanica OZ, Marchesini, RKExcel
www.kannichmotorsportsblog.com
Alias is offline   Reply With Quote
Old 03-13-2013, 12:19 PM   #5 (permalink)
BP
BP's Avatar
Talk to Whitehendrix here on the boards. The dude's a mad scientist with pretty much everything motorcycles.
2005 Raw Ti ZX6R
BP is online now   Reply With Quote
Old 03-13-2013, 09:36 PM   #6 (permalink)
kawiman1's Avatar
trying to get ahold of someone on here is tough they take days or weeks to respond
Old 03-14-2013, 01:56 AM   #7 (permalink)
kawiman1's Avatar
does the nipple on the fpr work like a fmu. i see so many people not using it, does it give better reading
