How to: replace your clutch plates - Page 3 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 09-26-2010, 02:04 PM   #21 (permalink)
roadrash32433's Avatar
roadrash32433 has at least 250 rep pointsroadrash32433 has at least 250 rep pointsroadrash32433 has at least 250 rep pointsroadrash32433 has at least 250 rep pointsroadrash32433 has at least 250 rep points
thanks guys! do you know by chance what size the nut is and the torque for reinstallation?
It's a beautiful day!!!
'02 ZX6R-M4 exhaust, Stage II Factory jet kit, Sprockets: -1 front, +5 rear, K&N air filter, Zero Gravity double bubble, carbon fiber sliders and levers, pro grips, integrated smoked tail light and rear hugger!!!
roadrash32433 is offline   Reply With Quote
Old 09-26-2010, 02:10 PM   #22 (permalink)
whitehendrix's Avatar
not sure man. if i had to guess, probably 30MM. but could be between 28 and 32 probably
►Sept09 B.O.T.M. winner◄
Need A "How To"? CLICK ME!!
Old 10-08-2010, 06:57 AM   #23 (permalink)
prelupino's Avatar
prelupino has at least 2000 rep pointsprelupino has at least 2000 rep pointsprelupino has at least 2000 rep pointsprelupino has at least 2000 rep pointsprelupino has at least 2000 rep pointsprelupino has at least 2000 rep pointsprelupino has at least 2000 rep pointsprelupino has at least 2000 rep pointsprelupino has at least 2000 rep pointsprelupino has at least 2000 rep pointsprelupino has at least 2000 rep points
just did this, easy as pie, thanks~!
prelupino is offline   Reply With Quote
Old 10-08-2010, 08:14 PM   #24 (permalink)
Old 10-09-2010, 07:23 AM   #25 (permalink)
98Ninja6 has at least 1000 rep points98Ninja6 has at least 1000 rep points98Ninja6 has at least 1000 rep points98Ninja6 has at least 1000 rep points98Ninja6 has at least 1000 rep points98Ninja6 has at least 1000 rep points98Ninja6 has at least 1000 rep points98Ninja6 has at least 1000 rep points98Ninja6 has at least 1000 rep points
seems my thrust bearings may have decided to make some noise - any tips for checking/replacing etc?
in neutral;
clutch in - no noise
clutch out - mechanical noise that seems to be getting louder every few weeks
recently changed to Comp 4 15/40 which has made the gearbox much smoother
98Ninja6 is offline   Reply With Quote
Old 10-31-2010, 08:06 PM   #26 (permalink)
effortless636's Avatar
effortless636 has at least 10 rep points
seeking advice. When starting from stop the bike will shudder for a second or two occasionally, especially in excessive heat. also when downshifting this occurs. But not all the time. Is it time for a new clutch?
Not sure if this is b/c of cable adjustment or worn clutch, but when I coast the bike with clutch in, the bike isn't so smooth, so still a bit of engagement. But running out of cable length. Have 18 k on 05 zx6r. Any help appreciated.
effortless636 is offline   Reply With Quote
Old 10-31-2010, 11:33 PM   #27 (permalink)
in neutral;
i think i'd take the suspect bearing out and spin it with a drill or something.. see if it makes noise.. sometimes that shit is the problem, sometimes it's sound transmission thru case webbing.
fucked up ass b-more traffic kickin that bikes ass, eh? lol
18K is a pretty good amount of time on a clutch.. especially city riding.
i would at least inspect the clutch stack and check the anti-chatter rings.. see if they're still there and whatnot.
Old 11-01-2011, 09:16 PM   #28 (permalink)
New Quad User has at least 10 rep points
Hi, I habe a 87 klf300a 4x2 it has multi disc but it does not use a clutch is the instal the same?
New Quad User is offline   Reply With Quote
Old 12-07-2012, 06:53 AM   #29 (permalink)
tmrki has at least 10 rep points
Did you use torque wrench for spring bolts or is there another way? They have to be tight on 8,8Nm by the manual for zx6r 2007.
tmrki is offline   Reply With Quote
