Penn Foster
Old 10-10-2008, 01:02 PM   #21 (permalink)
Green_ZIXER has at least 10 rep points
07/08 have that black on the front fyi mine has it too...
Green_ZIXER is offline   Reply With Quote
Old 10-10-2008, 01:53 PM   #22 (permalink)
bluuuuuueberry
ZeRo_C0oL's Avatar
ZeRo_C0oL has at least 2000 rep pointsZeRo_C0oL has at least 2000 rep pointsZeRo_C0oL has at least 2000 rep pointsZeRo_C0oL has at least 2000 rep pointsZeRo_C0oL has at least 2000 rep pointsZeRo_C0oL has at least 2000 rep pointsZeRo_C0oL has at least 2000 rep pointsZeRo_C0oL has at least 2000 rep pointsZeRo_C0oL has at least 2000 rep pointsZeRo_C0oL has at least 2000 rep pointsZeRo_C0oL has at least 2000 rep points
Nice!
Adam
2001 lightning candy blue ZX6R (sold)
2005 candy plasma blue ZX6R/636
2006 ZX10R (sold)
Roanoke, VA
ZeRo_C0oL is offline   Reply With Quote
Old 10-12-2008, 01:24 PM   #23 (permalink)
silverbullet2005's Avatar
silverbullet2005 has at least 250 rep pointssilverbullet2005 has at least 250 rep pointssilverbullet2005 has at least 250 rep points
http://www.bestbyteinc.com/FAN-LOG-8GNC.html has them for $5.75 each plus shipping
2008 ZX-10R & 2007 ZX-6R
ProGrip 724 Grips - Harris ZX Performance Tank Pads
T-REX Frame Sliders & Swingarm Slider/Spools
Pure Green Gauge Backlighting - Micron GP Sidewinder, OEM Seat Cowl - Star Lights Xenon Headlights - & More!
silverbullet2005 is offline   Reply With Quote
Old 10-30-2008, 12:52 AM   #24 (permalink)
hyperionjr's Avatar
hyperionjr has at least 350 rep pointshyperionjr has at least 350 rep pointshyperionjr has at least 350 rep pointshyperionjr has at least 350 rep points
Question for poster:
Did you caulk all around the ccfl or did you just "dab" a couple spots? Did you also use the same caulk to fit the headlights back together or does the original adhesive come back to life when you heat it?
thx
OIF 1 Veteran... and U.S. supporter regardless of who we are beating up.
2008 "Custom White" ZX6R ...uhh...modded.
hyperionjr is offline   Reply With Quote
Old 10-30-2008, 12:00 PM   #25 (permalink)
nonelower2001's Avatar
nonelower2001 has at least 1000 rep pointsnonelower2001 has at least 1000 rep pointsnonelower2001 has at least 1000 rep pointsnonelower2001 has at least 1000 rep pointsnonelower2001 has at least 1000 rep pointsnonelower2001 has at least 1000 rep pointsnonelower2001 has at least 1000 rep pointsnonelower2001 has at least 1000 rep pointsnonelower2001 has at least 1000 rep pointsnonelower2001 has at least 1000 rep points
i just reheated mine and used the original adhesive to put them back together. I used caulk around the whole light. and then some on the hole I drilled to get the wires out of the headlight. I drilled a small hole and cut the plug off and then put it back together on the other side.
08 Blue ZX6R ,Blue Halo lights, Super bright headlights, PCIIIUSB, Removed secondary butterflys, Jumper Mod, T-Rex frame slider, Rear brake resevoir relocation, DIY finder eliminator, Gutted Cat, CF Scorpion Slip-on, Pro-Grip Gel grips, kleen air mod, Ram air Mod
nonelower2001 is offline   Reply With Quote
Old 10-31-2008, 11:39 PM   #26 (permalink)
Motarmacycle Parts Dood
Pramslam's Avatar
Pramslam has at least 250 rep pointsPramslam has at least 250 rep pointsPramslam has at least 250 rep pointsPramslam has at least 250 rep points
thx
I caulked around the entire CCFL. I felt it was much more secure that way. I didn't use any caulk to fit the lights back together, just reheat it. If you caulked the headlight to fit it back together, it may not line up right.
Also, unlike the above poster, I didn't drill a hole to put the wire through, I just layed it under the rubber round pieces that cover the holes.
Thusly:
http://img.photobucket.com/albums/v2...4/IMG00390.jpg
Also, I finally wired the switch, so it looks flush and not just hanging there. I'll have pics tommorow.
Pramslam is offline   Reply With Quote
Old 11-25-2008, 11:36 PM   #27 (permalink)
n!ghtr!der has at least 150 rep pointsn!ghtr!der has at least 150 rep points
I am a little confused as far as the wiring... as I'm not very "electrically" inclined.
I understand linking the left and right CCFL's to the inverter, and the toggle switch connects to the inverter as well.
1. How do you "Plug to Bike"? Are you hooking it straight up to the + and - on the battery?
Sorry for the dumb questions, I just want to make sure I'm doing this right!!
N!ght R!der
n!ghtr!der is offline   Reply With Quote
Old 11-26-2008, 02:35 AM   #28 (permalink)
fishinking86's Avatar
fishinking86 has at least 2000 rep pointsfishinking86 has at least 2000 rep pointsfishinking86 has at least 2000 rep pointsfishinking86 has at least 2000 rep pointsfishinking86 has at least 2000 rep pointsfishinking86 has at least 2000 rep pointsfishinking86 has at least 2000 rep pointsfishinking86 has at least 2000 rep pointsfishinking86 has at least 2000 rep pointsfishinking86 has at least 2000 rep pointsfishinking86 has at least 2000 rep points
subscribed
-Why do women love civil engineers? Because civil engineers build the world's largest erections.
--I'm gonna make like a fetus and head out.
---You're hungry? How about I give you a knuckle sandwich?!
fishinking86 is offline   Reply With Quote
Old 11-28-2008, 01:45 AM   #29 (permalink)
dogszzr has at least 10 rep points
This is a great write up and very informational. I have a silver zzr600, and I know in my state blue or red up front won't fly with the cops. I want to do halo/angel eyes, but I ride with high beams on in the day so I don't think the white will work. I was thinking, what if I rocked a black ccfl as halos instead. What do you guys think?
dogszzr is offline   Reply With Quote
Old 12-13-2008, 01:42 PM   #30 (permalink)
Killa96Zx-9r has at least 10 rep points
thats sick man thanks for sharing
Killa96Zx-9r is offline   Reply With Quote
vB code is On
