Old 08-13-2008, 03:27 PM   #1 (permalink)
Motarmacycle Parts Dood
Pramslam's Avatar
Pramslam has at least 250 rep pointsPramslam has at least 250 rep pointsPramslam has at least 250 rep pointsPramslam has at least 250 rep points
Send a message via AIM to Pramslam
Default How-to $12 Headlight Halo
$12 plus shipping, I bought the parts from www.svc.com, search for 80mm CCFL.
Link to Search:
http://search.store.yahoo.net/cgi-bi...g=svcompucycle
All I used were the 2 fans, with the CCFL tubes. There was heat shrink, from my place that I also used. But basically, there were no additional parts.
I wired the front light to the halos, cause I got a fix it ticket for the green front light, and the switch kills all the lights. I'm sure you could make your own wiring system, but this one works for me.
CCFL Fan
CCFL Fan and tools
Opened fan
Close up fan
Removed Light
Cutting zip tie
Separated
Wires
Toggle switch
Removed Toggle
Computer wires
Removing needed wires
Removed Wires
Clipping power wire
Wiring harness
2 CCFL tubes
Plastic off CCFL tubes. Note: I left the plastic on, when I installed it on the lights, it was a tight fit, almost like it was made to be put on like that.
Inverter, you need this, I believe it inverts the the power from D/C to A/C or something like that.
All connected together
Continued in next post.
Pramslam is offline   Reply With Quote
Old 08-13-2008, 03:28 PM   #2 (permalink)
Pramslam's Avatar
CCFL light test
Front fairing off
Front fairing
Taking off headlight
Headlight assembly
Where I attached the inverter. The fans come with Velcro.
Bike with no headlights
Prying apart headlights
Heatgunning the headlight to rip it in pieces.
Pulling apart headlight. Note: I heard you can bake the headlights, but this way worked for me, you can bake em, or whatever you want to do, to get them apart.
Front headlight
Front headlight assembly
Attaching CCFL tubes
Headlight boobs
Clear silicone sealant. Note: This stuff dries on clear, and reacts well to heat, so they won't move, or pop out with vibration, I highly suggest using some type of sealant, as the CCFL tubes could potentially move
Wiring it out
Number 2 headlight
Sealing number 2
Close up of sealant
Continued on next post.
Old 08-13-2008, 03:29 PM   #3 (permalink)
Pramslam's Avatar
Wiring both through
Testing
1 eyed headlight
Wiring picture
Put back on rubber seal
Reattaching headlight
Reattaching front fairing
Wiring
Inverter wired up
Attaching underside panel, with attached inverter
Switch. Note: I haven't attached the switch anywhere, it just hangs loose, I plan to get a marine grade switch that is water proof and attach it somewhere, but for now, it works as is.
Lights on, headlights off
Close up
Lights on, and headlights on
Lights off, and headlights on
How I wired everything up.
Thoughts and notes:
I touched the bulb upon replacing it, so now you can see fingerprints on it, but you have to be looking for it.
I tried to angle the dark spot on the halos to the bottom, toward the center of the fairing, on both sides, but it turns out you can see them pretty clearly, and it would be better if they were angled towards the top center, or even top outwards.
This took a total of about 3 hours. I wired it all, not the to electrical harness because that part is expensive to replace, wire it to the headlight wiring harness, please.
Any questions?
Old 08-13-2008, 04:00 PM   #4 (permalink)
SushiMe's Avatar
SushiMe has at least 500 rep pointsSushiMe has at least 500 rep pointsSushiMe has at least 500 rep pointsSushiMe has at least 500 rep pointsSushiMe has at least 500 rep pointsSushiMe has at least 500 rep pointsSushiMe has at least 500 rep pointsSushiMe has at least 500 rep points
Wow great write up! I once had a bad incident baking my car headlights haha, so I won't be attempting this.
SushiMe is offline   Reply With Quote
Old 08-13-2008, 07:25 PM   #5 (permalink)
z28forlife has at least 500 rep pointsz28forlife has at least 500 rep pointsz28forlife has at least 500 rep pointsz28forlife has at least 500 rep pointsz28forlife has at least 500 rep pointsz28forlife has at least 500 rep points
Very nice writeup.
z28forlife is offline   Reply With Quote
Old 08-13-2008, 07:40 PM   #6 (permalink)
DarkZXRider has at least 50 rep pointsDarkZXRider has at least 50 rep points
you are my newest and latest and bestest and awsomest hero!
but i'm not going to do it, sincei know i will phuck up my headlight =(
DarkZXRider is offline   Reply With Quote
Old 08-13-2008, 08:48 PM   #7 (permalink)
KawiRoostar has at least 50 rep points
Fantastic work. I will definately follow this guide.
KawiRoostar is offline   Reply With Quote
Old 08-13-2008, 08:56 PM   #8 (permalink)
desi778's Avatar
desi778 has at least 50 rep pointsdesi778 has at least 50 rep points
good job and nice write up...
debadged, 07 black
desi778 is offline   Reply With Quote
Old 08-13-2008, 09:43 PM   #9 (permalink)
Pramslam's Avatar
If you like them, I think you should do it. It's definitly worth it. They're only a, what?, 450 dollar headlight assembly? ;-)
The part that made me most afraid was the baking, but since I didn't have to do that, it was cake.
Seriously, I had cake afterwards.
Old 08-13-2008, 10:36 PM   #10 (permalink)
desi778's Avatar
if you baked them it would have been a lot easier...
200 degrees for 10 minutes and it pulls apart... same thing when you put it back together...
debadged, 07 black
