Old 09-25-2008, 11:27 AM   #11 (permalink)
IHP mod
nevada's Avatar
while this is a great idea.
ive got a question. how do you set the pin depth?
on my rivet tool, theres a small recessed area, tha lets the pin go back so far, then stops it. keeping it flush with the rest.
how did yours look when you were done?
05 zx6r green 26,000+ miles
RIDE YOUR OWN RIDE.
Originally Posted by xxXJasonXxx View Post
Good gear is way cheaper than getting hurt.
I HATE PEOPLE. Yes, that includes you.
Old 09-25-2008, 11:29 AM   #12 (permalink)
meangreen7r's Avatar
meangreen7r has at least 4000 rep pointsmeangreen7r has at least 4000 rep pointsmeangreen7r has at least 4000 rep pointsmeangreen7r has at least 4000 rep pointsmeangreen7r has at least 4000 rep pointsmeangreen7r has at least 4000 rep pointsmeangreen7r has at least 4000 rep pointsmeangreen7r has at least 4000 rep pointsmeangreen7r has at least 4000 rep pointsmeangreen7r has at least 4000 rep pointsmeangreen7r has at least 4000 rep points
Originally Posted by mr.croom View Post
1/2 drive air wrench, and make sure you have plenty of air pressure built up in your compressor.
tried 2 different impact guns, big ass breaker bar, heat, reverse threading....nothing would break the thing loose. yes i bent back the safety washer or whatever it is.
meangreen7r is formerly known as sweetzixxer
Originally Posted by jmat2407 View Post
Without a doubt.
Hell for a billion? I'd let you have your way with my asshole afterwards too.
meangreen7r is offline   Reply With Quote
Old 09-25-2008, 11:33 AM   #13 (permalink)
AKA "White Dynamite"
mr.croom's Avatar
mr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep points
Send a message via Yahoo to mr.croom
Any idea what kind of torque the impact wrench makes? What psi were you running them with? Drive sprockets are a bitch............
http://i193.photobucket.com/albums/z158/mrcroom/croom_sig-2-1-1.jpg
mr.croom is offline   Reply With Quote
Old 09-25-2008, 11:37 AM   #14 (permalink)
not sure about one but i think it was the more powerful of the 2. on was a craftsman rated to 90 psi but not sure of the fl/lbs, the compressor was putting out more than 90 psi at one point and still nothing. would it make a difference if i wasn't using an actual impact socket with the gun??
Without a doubt.
Old 09-25-2008, 11:39 AM   #15 (permalink)
mr.croom's Avatar
The socket wouldnt make any difference, except that an impact socket is made to stand the abuse of continuous high torque impact. I think your gonna need a gun with a higher torque rating..................
Old 09-25-2008, 11:42 AM   #16 (permalink)
IHP mod
nevada's Avatar
The socket wouldnt make any difference, expect that an impact socket is made to stand the abuse of continuous high torque impact. I think your gonna need a gun with a higher torque rating..................
actually, the socket can make a difference. i see it all the time.
use an impact socket. since usually they are thicker/heavier. and use the shortest one that will fit completely over the nut. and make sure its the right size. a tiny bit big, might work, in theory. but you lose a lot of strength with it rattling around on the nut.
RIDE YOUR OWN RIDE.
Old 09-25-2008, 11:55 AM   #17 (permalink)
hmmm...maybe i'll have to give it another try this weekend before i give up and take it to the dealer. really sucks though cuz i wanted to do it myself.
Without a doubt.
Old 11-06-2008, 09:09 AM   #18 (permalink)
mr.croom's Avatar
Sorry dude, I just now saw this question as I scanned back over this thread.
My new chain came with shims that you place above the o-rings to keep the link plates properly spaced. I'll post pics later for those who want to see them...........
Old 01-06-2009, 02:52 PM   #19 (permalink)
asteelo's Avatar
asteelo has between 50,000 and 60,000 rep pointsasteelo has between 50,000 and 60,000 rep pointsasteelo has between 50,000 and 60,000 rep pointsasteelo has between 50,000 and 60,000 rep pointsasteelo has between 50,000 and 60,000 rep pointsasteelo has between 50,000 and 60,000 rep pointsasteelo has between 50,000 and 60,000 rep pointsasteelo has between 50,000 and 60,000 rep pointsasteelo has between 50,000 and 60,000 rep pointsasteelo has between 50,000 and 60,000 rep pointsasteelo has between 50,000 and 60,000 rep points
Send a message via Skype™ to asteelo
Will this work on an EK chain with the pin rivets? They say to use their special tool, but thats at least $50 i dont want to spend.
asteelo is offline   Reply With Quote
Old 01-06-2009, 03:14 PM   #20 (permalink)
mr.croom's Avatar
Yes sir it will.
