MPH to KPH
48K views 9 replies 6 participants last post by  texasxdevil
#1 ·
Does anyone know if you can change the speedo from MPH to KPH. I am moving to Germany in a few months and will need to change it over so i don't speed too much out there, ya know.
#10 ·
Never mind everyone I GOT IT!!:D:D:D:D Yeah so what you do is.....
A: Turn on Bike, not running
B: Make sure the Odometer is on, not trip
C: Press and Hold MODE
D: Press Reset until correct reading
It will go through a couple of setups, one is KPH with F temp and miles on the Odo, and it will change KPH, Degrees, Or total miles/Kilos. Just keep watching the read out and pick what you want.
I hope this helps some one else, if not then i guess i just need to get a owners manual.:D
