how to replace spark plug 07-08 zx6r - KawiForums - Kawasaki Motorcycle Forums
post #1 of 11 (permalink) Old 03-27-2010, 05:13 PM Thread Starter
crash_42's Avatar
Send a message via Yahoo to crash_42
*First things first it to take off the seat...
*after seat removal you will see this. I have marked everything that needs taken apart here in the yellow...
*remove both front (2)bolts and rear tank (1 long bolt)
*unsnap both clips that are attached to the fuel pump (one red clip is on the fuel pump) (the other is the wiring that runs from the pump)
*and unbolt the cover which hides the butterflies on you air box
* hidden screw down where I am pointing
*go all the way around unscrewing the black bolts holding the lid together
* unscrew top bolt (near steering stem)
*unclip the little green clip
* to the right of airbox pop off the black fuse box connected on the side
* now take out the filter and pull (HARD) on the bottom of the airbox
2008 plasma blue zx-6r (custom windscreen, 5150 concept rearsets-jumper mod-vortex gas cap/base- stomp grippy- prs frame sliders-DDM tuning HID 35w 8000k lights - moto gp shift- shorty kickstand - rear seat cowl-pciii-block off plates-kleen air mod- removed the kitty, two brothers slip-on-bmc race)
crash_42 is offline
post #2 of 11 (permalink) Old 03-27-2010, 05:18 PM Thread Starter
crash_42's Avatar
* unhook the hoses will be (2 hoses one in the front and the right side) leading to the airbox
*now the fun part! getting the plugs out.
*unsnap the clips that are connecting the four plugs
*I had to bend and move the hoses and wires out of the way
* Now you have to twist and pull (Hard) to get the boots off the plugs (pointing at boots)
*now after that you just unscrew the plugs and replace them with the new *
*(ngk cr9e)
then do this process backwards to get everything back together!
crash_42 is offline
post #3 of 11 (permalink) Old 04-02-2010, 07:25 AM
RhinoAK's Avatar
Real good demo. Thanks!
RhinoAK is offline
post #4 of 11 (permalink) Old 04-03-2010, 11:50 AM
SushiMe's Avatar
SushiMe is offline
post #5 of 11 (permalink) Old 04-03-2010, 03:09 PM Thread Starter
crash_42's Avatar
thanks!
crash_42 is offline
post #6 of 11 (permalink) Old 04-09-2010, 08:07 PM
Grimmy's Avatar
Nice dude! Good job. Will put it in my favs under motorcycle guides for when the time comes.
...2009 ZX6R Monster... - I'm new here so be nice to me -
Haves = Sportech Skull Tank Pad + Windscreen, B2 Ind. Rails, M4 Slip-On
Have Nots = Scorpio Rlink Alarm, Hotbodies Undertail Tran Smoke,
Grimmy is offline
post #7 of 11 (permalink) Old 04-26-2010, 02:22 AM
When pulling the airbox out it helps to loosen the allen bolts behind the frame plugs on either side of the airbox (tiny allen)... it loosens where the bottom of the airbox is...great writeup!
T-Rex Swingarm Spools and Frame Sliders, K&N Air Filter, Jumper mod, Kleen Air Mod, PC3 with custom Dyno, Puig DB, Bridgestone Battlax BT016s, GP Shift Pattern, Rear Brake Reservoir Relocate, Rear Peg Delete, Keiti Rim Striping, Galfer SS Brake lines, ProGrip Tank Pad, Dual F/E Kits (Sportbikelites and Pinebox), StompGrip, Fill Ti Arata Racing Exhaust and KawiForums DECALS!!!! Woot!!!
TheDataChef is offline
post #8 of 11 (permalink) Old 06-15-2010, 10:58 PM
othebe's Avatar
Im a little lost after I removed the air filter... I need to remove the whole box (the bottom part) but theres something holding it in. Could anyone put up some pictures as to exactly where those bolts are.
Much appreciated. Thanks.
othebe is offline
post #9 of 11 (permalink) Old 06-15-2010, 11:05 PM
hedz0r's Avatar
on the sides on the frame there are to plugs (or caps.. whatever.. their plastic) pop those off. inside you can see a 3mm (i think its 3mm) allen head screw. dont completely remove them, just loosen. (both sides) and the airbox will pop off.
Everyone should believe in something, I believe I'll have another BEER.
hedz0r is offline
post #10 of 11 (permalink) Old 06-15-2010, 11:37 PM
othebe's Avatar
oh so those things pop off... lol... I was wondering what those were!
othebe is offline
