Guide to How-To Navigation : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 09-26-2010, 07:17 PM   #1 (permalink)
whitehendrix's Avatar
Default Guide to How-To Navigation.. New and Improved
****under construction****
i am trying to "group" these as best as i can. transmission related stuff, lighting related stuff, FI light stuff and so on.. but i have ADD and i make no promises on organization.
you owe anyone who's info you use either rep points, money, or alcohol and/or titties. this is saving you a shit ton of money and taking money out of my pocket as well, since this is what i do for a living.
noobs: your reps are neutral for a while so.. i'll just take money instead..
the authors of this information can not be held liable for damages due to mechanical ineptitude, incompetence, negligence, workmanship (or lack thereof), damages to property,or physical harm to yourself or others. furthermore, I am not responsible for the accuracy of the information contained herein. use at your own risk. (except my info. it's the shit. )
General Powertrain
How to..Understand octane
*Octane, what is OK.
How to.. Understand oil viscosities and ratings
*A little help understanding Oil Weights
How to..WINTERIZE your bike
*How To - Winterize
*Winter storage? (THE Winterization question/answer thread for 250's)
How to..sync the carbs/throttle bodies
*Syncronize your throttle bodies!
*carburator synchronization made kinda simple
How to..adjust carbs
*Universal Float Setting For Any Carburetor
*Fuel screws?
*Raising the Needle Jets..Mod.
How to, change your spark plugs
*how to replace spark plug 07-08 zx6r
*HOW TO: change spark plugs 06 636
How to..change your oil
*Changing the oil... 03-04 6R
*Change your oil - 2005 6R 05 6R
*07/08 Oil Change, The Ultimate Guide! Pic Intensive! 07-08 6R
*http://www.kawiforums.com/ninja-250r...rocedures.html 08 250
*http://www.ninjette.org/forums/showthread.php?t=10780 250
*HOW TO change the OIL in your Ninja 250 - VIDEO 250
How to..burp your oil filter
*Burping your baby after an oil change
How to.. cross reference an oil filter
*http://www.calsci.com/motorcycleinfo/FilterXRef.html
How to..Change/flush your coolant system
*DIY - Coolant flush and refill (for 250R)
How to..bump your CCT
*How to: adjust the factory CCT on a 636
How to..do a valve adjustment
*96-03 ZX7R valve adjustment
*valve adjustment (also for the 7R.. but everything translates to other bikes)
How to..do the Kleen air mod
*07/08 zx6r kleen air mod
*How to: KLEEN Air Mod 05-06 ZX6R COMPLETE. UPDATED
*07-08 6r Kleen Air Mod - Video
*DIY- Removing the Kleen Air System Hoses and Plugging the Holes on a 08 250R
*Remove CA smog crap & PAIR/KLEEN mod '05/'06 ZX6R
How to..replace shift forks and do trans repair
*05-06 ZX6R/RR Change out shifting forks
*1999 zx9r tranny swap 2000
How to..install an aftermarket shift star
*Factory Pro Shift kit- 05/06 zx6r
*Installing a Factory Pro Evo shift Star
How to..replace your clutch
*How to: replace your clutch plates
*How To install Clutch Kit
*Clutch Assembly Tips
How to.. remove your cat ( this is illegal, mind you, but its not like the exhaust police will probably get you unless you're in Nazi cali or virginia)
*DYI cat removal zx6r 2007-2008
How to..Bypass your tip-over sensor
*vehicle down sensor bypass instructions
Driveline Maintenance
How to..make your own chain rivet tool
*Diy Chain Rivet Tool
How to..clean/replace your chain
*CLEAN your CHAIN Fast & Easy! Really CLEAN!
*How to replace your chain (w/ pics)
How to..remove sprockets
*FRONT SPROCKET! HOW TO on my '05
*Get your nut off!
* how to remove front sprocket
How to..replace wheel bearings
*Get your bearings right
Performance, tuning and modification
How to..calculate various engine numbers with advanced math
*random engine-related formulas
How to..start understanding and size a turbo system
*Basic turbo info
How to.. understand combustion so much it'll stop making sense.
*Combustion- ULTRA super uber in-depth
How to..do the jumper mod
*Jumper Mod
*Jumper Mod (different from the one above)
*Wiring mod for ZX6R/ZX6RR 2005-06
How to..install X-TRE
*07/08 X-TRE Install How-To
How to..find a Power Commander Map
*Power Commander Map Database
Old 09-26-2010, 07:17 PM   #2 (permalink)
Default Pg.2 -"Why does......", and more how-tos
General Chassis, Body and Suspension
How to..remove the front tire and/or rear and/or axle
*How To: Remove the front wheel
*Remove your wheels, and put them back on.
*how to remove front axle
*how to remove front wheel
How to..bleed your brakes/change fluid
*Easy Peasy Brake Bleeding
*How to bleed brakes
*Ok, I got the Vacuum Pump/Brake Bleed Kit. Now how do I use it?
*Brake bleeding and fluid change procedure!!
*Brake Fluid change & bleeding: tutorial. (video)
How to..understand/set suspension
*Suspension Help - Trouble Shooting - Learn the Lingo
How to..change your fork seals
*Fork seal replacement
*How to: replace fork seals on inverted forks
*How-to: Dismantle inverted forks (pic heavy)
How to..install lowering links
*DIY: Installing Roaring Toyz Lowering Links
*How to Lower your bike.
How to..chop/shorten your kickstand ( for lowered bikes)
*07/08 Shorten Your Own Damn Kickstand!
How to..make a fender eliminator
*http://www.kawiforums.com/2009-zx-6r...ml#post2104593
How to..hide/relocate your rear brake reservoir
*How to relocate the rear brake reservoir
How to..repair your plastics
*Fairing Repair
*How to fix your plastics (pic intense)
*How to - Paint and repairing fairings
How to..paint your windscreen
*How To Paint/Tint Your Windscreen
How to.. tint your.. whatever. tail, lenses, ect.
*http://www.kawiforums.com/2007-2008-...ml#post2139172
*How to tint you headlights and taillights
WHY WHY WHY !!???
Why cant..I post a thread anywhere here?
*how come i can only post in newbe section
Why Does.. my turnsignals flash at a retarded rate with a new LED taillight?
*Signal Light
*http://www.kawiforums.com/2009-zx-6r...ml#post2215895
Why Does.. My bike make a machine gun/buzz/rattle sound when i try to start it?
*How to.. understand electrical crap, battery stuff, and jumpstarting myths.
Why did..a piston come thru my lower case?
*why engines fail
(more how-to...)
General Disagnostics
How to.. know what code numbers are what actual problems
*trouble code list???
How to..pull trouble codes
*How To: Pull FI codes
*03-04 ZX6R[R]: How To Perform Self Diagnosis
How to..clear trouble codes
*Clearning an F1 Code
How to..do the FI light "fix" (or exhaust servo mods)
*How To: FI Light Fix
*How To Get Rid of Servo Motor Chatter
*Another DIY FI Light Fix
How to..make general diagnostics on your bike
*http://www.kawiforums.com/how-tos-fa...sdpection.html
General Riding tips, techniques and questions
How to..Become a better rider
*Advanced Tips for Street Riding - The Minor Things
*How To..Not crash ( so much) pt 1
*Good riding tips.
*If you have never ridden a motorcycle
How to..Choose What line to pick on a rainy day
*Rain Riding Position?
How to..select the right fuel
Racing/competition related
How To.. Get startin in road racing
*How-To: Go Road Racing
How to..Prepare for a track day event
*How-To: Prepare for a track day
How to..Get started in drag racing
*Best Technique (the basics and beyond)
How to..Install a 6R shock on your 250R
*ZX6R rear shock *sorta* howto
How To..general 2009 ZX6R shit
*http://www.kawiforums.com/2009-zx-6r...-tos-faqs.html
How to..general 07/08 ZX6R shit
Full 07/08 How-To Compilation Thread.
How To.. Build a rear stand
*250 project for the day
Old 09-26-2010, 07:18 PM   #3 (permalink)
Default Pg.3 *reserved for future additions*
Chassis electrical and lighting
How to..get schooled in electrical theory, battery stuff, troubleshooting
* How to.. understand electrical crap, battery stuff, and jumpstarting myths.
* Batteries: "Will it explode?" Edition
*Fault Finding Flowchart - Electrical Systems
How to.. get your turn signals to stop flashing all retarded like.
*How To: Install resistors when replacing turn signals.
How To.. make your own LED Taillights
*DIY LED turn signals
*Custom LED tail for a 92 ZX7
How to... figure out what bulbs you have
*official 07-08 zx6r complete bulb size thread
*KAWISPEED - View topic - Identify those bulbs
How to..do an HID kit or system
*How To: Install XeBrite "Plug-n-Play" Projectors
*HOW TO: HID/PROJECTOR RETROFIT 636
*HID install (sold by Allenchang) 2006 636
*http://www.kawiforums.com/2009-zx-6r...-how-hids.html
How to..do a dual headlight conversion
*Dual Headlight Configuration-Updated
*Dual Headlight kit Installation
*detailed dual headlight conversion
How To.. change your gauge lighting
*LED gauges-cheap how to
*Changing your backlight color in your gauges
*Changing your gauge color v. old school zx6r
*How To: 07/08 Gauge Color Change
How to.. change you MPH to KPH, C to F, set clock..
*setting the clock E9
*Setting clock on 07 zx-6r
*MPH to KPH
How to..replace your battery
*How To Change a Battery on 05/06 ZX-6R
Old 09-26-2010, 07:19 PM   #4 (permalink)
Default Pg.4 *Reserved for future additions*
and god forbid i am alive within 10 years, page 4 for future expansion
Old 09-26-2010, 07:43 PM   #5 (permalink)
5 maybe just in case
Old 09-26-2010, 07:44 PM   #6 (permalink)
and 6 cuz i really dont know either. i have alot of editing to do.
Old 10-02-2010, 05:00 AM   #7 (permalink)
abtanner has at least 10 rep points
IN ADVANCE, please forgive me. I cant find (search) anything relating to replacing the Brake Pad on an 1st Generation ninja 250r. My ride: "Ninja, 2004,250R". Plenty 'how tos &vids' for the '08+ Ninja 250R's, but nothing for our Old and forgoten 1st Gen Ninja 250R's.
Please help, and TIA, Al
abtanner@att.net
abtanner is offline   Reply With Quote
Old 10-03-2010, 11:19 PM   #8 (permalink)
should be the same? been a long time since i did brakes on a 250.. if i find a how-to i'll post it.
►Sept09 B.O.T.M. winner◄
Need A "How To"? CLICK ME!!
Old 11-04-2010, 01:32 PM   #9 (permalink)
chuckbear's Avatar
chuckbear has at least 80,000 rep pointschuckbear has at least 80,000 rep pointschuckbear has at least 80,000 rep pointschuckbear has at least 80,000 rep pointschuckbear has at least 80,000 rep pointschuckbear has at least 80,000 rep pointschuckbear has at least 80,000 rep pointschuckbear has at least 80,000 rep pointschuckbear has at least 80,000 rep pointschuckbear has at least 80,000 rep pointschuckbear has at least 80,000 rep points
what say you about adding a link to the FI codes? I ask because I just came here because I assumed you would have covered this in your infinite knowledge.
Originally Posted by locknload View Post
you will never teach a boy to be respectful by being a disrespectful man.
chuckbear is offline   Reply With Quote
Old 11-04-2010, 03:59 PM   #10 (permalink)
Smalls's Avatar
Smalls has at least 1000 rep pointsSmalls has at least 1000 rep pointsSmalls has at least 1000 rep pointsSmalls has at least 1000 rep pointsSmalls has at least 1000 rep pointsSmalls has at least 1000 rep pointsSmalls has at least 1000 rep pointsSmalls has at least 1000 rep pointsSmalls has at least 1000 rep points
Is it just me or is this thread really hard to navigate through...
******>>>>>J/K<<<<<***** (<--better?)
Thanks for the awesome section. I have another How To on fairing repair if you want to add it. I wrote this one up last year (lots of pics) and it works very well.
Fairing Repair
Smalls is offline   Reply With Quote
