2003 Z1000 coolant change : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 12-08-2012, 08:38 PM   #1 (permalink)
rkoe17's Avatar
rkoe17 has at least 50 rep points
Default 2003 Z1000 coolant change
Anybody have a how to or advice on changing coolant on a 2003 Z1000. Never done it before but I can't find the drain plug and read somewhere that I may have to take the tank off. Any advice is appreciated.
rkoe17 is offline   Reply With Quote
Old 12-08-2012, 11:20 PM   #2 (permalink)
ballin 03 636's Avatar
ballin 03 636 has between 5,000 and 7,500 rep pointsballin 03 636 has between 5,000 and 7,500 rep pointsballin 03 636 has between 5,000 and 7,500 rep pointsballin 03 636 has between 5,000 and 7,500 rep pointsballin 03 636 has between 5,000 and 7,500 rep pointsballin 03 636 has between 5,000 and 7,500 rep pointsballin 03 636 has between 5,000 and 7,500 rep pointsballin 03 636 has between 5,000 and 7,500 rep pointsballin 03 636 has between 5,000 and 7,500 rep pointsballin 03 636 has between 5,000 and 7,500 rep pointsballin 03 636 has between 5,000 and 7,500 rep points
I haven't worked on my z1000 in a while but from what i remember you need to take the fuel tank off to access the filler neck and cap to fill the new coolant, just remove the lowest hose that goes to the engine block i believe is on the left side the large one and let is drain out. Flush the system by putting the hose back up fill up the system with distilled water run it for a while (or not your choice) and drain the hose again after that add new coolant.
In the stable: "Studies show geniuses choose green"
2003 zx6r 636 Green 118whp (my baby) Husaberg fe501 street legal 55hp
2005 Honda cbr600rr
2005 z1000 RawTI
2005 Yamaha FJR1300 Abs Blue
ballin 03 636 is offline   Reply With Quote
Old 12-09-2012, 01:19 AM   #3 (permalink)
rkoe17's Avatar
Thank you sir! Doesn't sound too bad except that i have a full tank of fuel right now and it's 45 degrees and raining. Time to drain!
Old 12-09-2012, 04:06 PM   #4 (permalink)
rkoe17's Avatar
And is there a bolt on the front of the engine block to drain extra coolant?
Old 12-09-2012, 04:45 PM   #5 (permalink)
There may be one on the side of the motor on the water pump cover its probably the lowest one looks like a regular case cover bolt but im not sure, download the free service manual should cover it all. Also if you want to be really thorough take the hoses off the oil filter cooler and flush those too.
2005 Honda cbr600rr
2005 z1000 RawTI
Old 12-13-2012, 04:27 PM   #6 (permalink)
Rossi1981 has at least 10 rep points
Any ideas what bike is good for a short 5 mile commute?
Rossi1981 is offline   Reply With Quote
