Tip Over Switch - 636 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Closed Thread
Old 10-06-2004, 04:44 PM   #1 (permalink)
03ZX6Rider is around zero rep points
Send a message via AIM to 03ZX6Rider
Default Tip Over Switch - 636
Just incase anyone needed this. I crashed my bike a couple weeks ago and it wont start. It wasn't the tip over swtich, but the weight inside was off. I fixed it and still nothing but it could be YOUR problem...
...04 ZX6R...SOLD! I\'ll be back!!!
It KICKS ASS!!!
03ZX6Rider is offline
Old 10-06-2004, 04:49 PM   #2 (permalink)
The little wieght inside hangs fomr a little rod and is able to move back and forth. It has a counter wieght on the bottom so when the bike is str8 up the wieght inside the box is. Bike falls down, the box is an the same angle. Since the wieght is counter wieghted it stays str8 up and down. The arm on the wieght I think touches a contact on the top portion of the tip over box, causing the bike to shut off. This is what it looks like. I could be wrong. If bike ggoes down, check this first!! Hope I helped someone out!!
Old 10-06-2004, 04:54 PM   #3 (permalink)
Jay-Jay is around zero rep points
Hm....good looking out. It could be my problem along with my battery. I'll check mine today.
Jay-Jay is offline
Old 10-07-2004, 04:25 AM   #4 (permalink)
no problem man!
Old 11-23-2004, 01:11 AM   #5 (permalink)
smarticus is around zero rep points
Send a message via AIM to smarticus
i looped my bike when i riding riding a 12:00. i was at BP for prolly 1/8 mile. why didnt it shut off before i went over?
smarticus is offline
Old 12-24-2004, 06:50 PM   #6 (permalink)
Un-Stealth Administrator
skywalker's Avatar
skywalker has at least 80,000 rep pointsskywalker has at least 80,000 rep pointsskywalker has at least 80,000 rep pointsskywalker has at least 80,000 rep pointsskywalker has at least 80,000 rep pointsskywalker has at least 80,000 rep pointsskywalker has at least 80,000 rep pointsskywalker has at least 80,000 rep pointsskywalker has at least 80,000 rep pointsskywalker has at least 80,000 rep pointsskywalker has at least 80,000 rep points
Send a message via AIM to skywalker
Probably because it's a horizontal-axis tilt sensor, not a vertical axis tilt sensor.
skywalker is offline
Old 03-01-2005, 04:12 AM   #7 (permalink)
Fargo_flyer is around zero rep points
Send a message via AIM to Fargo_flyer Send a message via MSN to Fargo_flyer
[:Agree] I think your right. A vertical angle style sensor would also be subjective to acceleration/deceleration.
JJ
Fargo_flyer is offline
Old 03-18-2005, 12:39 AM   #8 (permalink)
playaz0429 is around zero rep points
no longer an issue in the 05, its automatic. unless you break it i guess.
playaz0429 is offline
Old 06-08-2005, 05:10 AM   #9 (permalink)
Disturbed6R's Avatar
Disturbed6R has at least 50 rep points
Send a message via AIM to Disturbed6R Send a message via Yahoo to Disturbed6R
Yeah you tilt it left or right too much and it shuts off. I'm going to remove it if I can
Disturbed6R is offline
Old 09-09-2005, 06:55 PM   #10 (permalink)
redhathakker is around zero rep points
Send a message via Yahoo to redhathakker
Why remove it? If the angle is extreme enough to trigger the tip sensor, your oil pump probably isn't picking up oil.
redhathakker is offline
Closed Thread
