garage door opener using lap timer, step by step - Page 6 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 03-01-2009, 10:30 PM   #51 (permalink)
integra3586 has at least 500 rep pointsintegra3586 has at least 500 rep pointsintegra3586 has at least 500 rep pointsintegra3586 has at least 500 rep pointsintegra3586 has at least 500 rep pointsintegra3586 has at least 500 rep points
awesome write up!!! I just did it to my bike. works like a charm!
integra3586 is offline   Reply With Quote
Old 03-11-2009, 12:07 AM   #52 (permalink)
DJ KO's Avatar
DJ KO has at least 50 rep points
i'm gona have to try this setup
DJ KO is offline   Reply With Quote
Old 06-03-2009, 02:54 PM   #53 (permalink)
Baedarlboo's Avatar
Baedarlboo has at least 250 rep pointsBaedarlboo has at least 250 rep pointsBaedarlboo has at least 250 rep points
Works like a charm! I had to use a 100ohm,150ohm, and a LM317 regulator to drop my voltage down to 3vdc (my garage door opener operates on a 3v batt.), then wire it to my LAP button. This was done on a 2007 ZX6R. The wire for the LAP button is on the left side instead of the right side of the bike.
Baedarlboo is offline   Reply With Quote
Old 07-05-2009, 09:07 PM   #54 (permalink)
tdli is around zero rep points
Just did this on my 03 636 and my lap timer wire was the same color ( white with pink strip) as this Diy. It was also the same pin slot.
'03 636, blue, 0Gravity screen, Pazzo Levers, Progrip grips, Motovation barends and sliders, Single HID, VFX flushmounts, Scott's damper, KLEEN air mod, K&N filter, Leo Vince CF HM & CA tail.
tdli is offline   Reply With Quote
Old 07-17-2009, 01:37 PM   #55 (permalink)
BTW, i noticed my garage door will not open/close sometimes when the bike's engine is turned on. it always works when the key is turned (but engine is not on).
does anyone know why?
Old 03-13-2010, 06:50 PM   #56 (permalink)
Mr. Regular has at least 10 rep points
I just completed this MOD on my 07 ZX6R last week.
I couldn't find a 12v remote for my door opener. Everything I found was 3v so I had to build a voltage regulator.
If anyone would like me to build them a voltage regulator to step down 12-14v to 3v let me know. You can PM me for details.
Mr. Regular is offline   Reply With Quote
Old 05-26-2011, 02:55 PM   #57 (permalink)
G Money's Avatar
G Money has at least 250 rep pointsG Money has at least 250 rep pointsG Money has at least 250 rep pointsG Money has at least 250 rep pointsG Money has at least 250 rep points
Does anyone have an answer for this???
Just completed the mod and I'm having the same result in that it won't open / close when the bike is running.
G Money is offline   Reply With Quote
Old 12-01-2012, 12:15 AM   #58 (permalink)
hoffmanlisa has at least 10 rep points
Default garage door opener using lap timer, step by step
Thank you, Every details are there. I'll try to apply that to my garage door opener.
hoffmanlisa is offline   Reply With Quote
Old 12-01-2012, 12:37 AM   #59 (permalink)
Old thread, but since the spammer bumped it...
A friend invented a garage door opener that is specific to motorcycles. Battery powered and mountable anywhere (FWIW he's been using the prototype for over 3 years and has yet to kill the battery.)
Check out Mo-Door Motorcycle Garage Door Openers
Currently own:
05 Z750S
Have owned:
01 Volusia
