How To Adjust A Motorcycle Chain : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Go Back   KawiForums - Kawasaki Motorcycle Forums > Open Discussion > Kawasaki News
LinkBack Thread Tools
Old 06-27-2016, 03:51 PM   #1 (permalink)
Motorcycle.com has at least 50 rep pointsMotorcycle.com has at least 50 rep points
Walk around at any motorcycle gathering and count the bikes with limp, sagging chains. Often, the worst examples also are bone dry with rust and/or crud built up on them. Since youíre a MO reader and regularly clean/lube your chain, youíre ahead of the game. However, you still need to make sure that the chainís slack is within specifications. If you lube your chain regularly, you will probably not need to adjust it every time you return from a ride, but as a chain nears the end of its usable life, you will need to adjust the slack more and more frequently.
Although a rear stand is not required to adjust your chain, it will make the process much easier. When your chain is cold, measure the slack halfway between the sprockets by moving the chain up and down. Press down on the chain slightly to make sure it is at its lowest point. To get an accurate reading, hold a tape measure in front of the chain and look across the top of the links. Adjust your line of sight until the tops of both sides of the chain line up, which assures your eyes are perpendicular to the chain and parallel with the top of the links.
Next, move the tape measure so that one of the inch markings aligns with the top of the chain. Now, press the chain up until it is tight, and, bringing your vision up to align the top of the chain again, note the measurement. A little math will tell you if you if the slack is within your bikeís recommended specifications. Since chains donít always wear evenly, check the slack measurement in a couple of places. If you need to adjust the chain, set the chain tension to accommodate the tightest point. Also, if the chain is dramatically tighter in one place, consider replacing it.
Find Out How To Adjust A Motorcycle Chain at Motorcycle.com.
Motorcycle.com is offline   Reply With Quote Quick reply to this message
» Recent Discussions
New to the bike world
05-14-2017 10:17 AM
Last post by Erics9971
Today 05:51 PM
4 Replies, 110 Views
Broken Steering Damper...
05-24-2017 09:45 PM
by Wizardy
Last post by FOG
Today 04:59 PM
3 Replies, 70 Views
Kawasaki ER-6f/650R...
Today 11:14 AM
Last post by FOG
Today 04:56 PM
1 Replies, 24 Views
Performance enhanced...
Yesterday 04:05 PM
by Haakon
Last post by Haakon
Today 03:59 PM
4 Replies, 46 Views
Auto-blip map.
Today 12:43 PM
Last post by joedog064
Today 12:43 PM
0 Replies, 11 Views
Hello from Serbia
Today 04:32 AM
Last post by GR rider
Today 04:42 AM
1 Replies, 23 Views
Newbie
Yesterday 07:06 PM
by cjissel
Today 03:13 AM
1 Replies, 36 Views
Newbie post, but a...
05-24-2017 06:33 PM
Last post by cjissel
Yesterday 07:05 PM
1 Replies, 39 Views
Starter motor isn't...
Yesterday 12:05 PM
Last post by ZZR600-2008
Yesterday 06:35 PM
1 Replies, 43 Views
HELP with throttle
05-24-2017 05:32 PM
Yesterday 06:17 PM
5 Replies, 57 Views
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
