How Do You Check A Motorcycle’s Oil Level? : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Go Back   KawiForums - Kawasaki Motorcycle Forums > Open Discussion > Kawasaki News
LinkBack Thread Tools
Old 09-02-2016, 10:21 AM   #1 (permalink)
Motorcycle.com has at least 50 rep pointsMotorcycle.com has at least 50 rep points
Modern motorcycles are incredibly reliable, but they still require you to check a few things in order to keep them running at full potential. The engine oil is one of those items you should never neglect. After all, you don’t want to run your high-revving, manufactured-to-aerospace-tolerances, and extremely-expensive-to-replace engine without the proper lubricant, do you? Additionally, an engine’s oil can reveal a good bit of information about the condition of its internals to even a novice mechanic armed with a little information.
To actually check an engine’s oil level, take a look at its owner’s manual. Seriously, it’ll outline the specifics that the manufacturer recommends – and they do vary slightly from bike-to-bike. Still, the steps do follow a rough pattern.
Make sure the engine is warmed to operating temperature. After turning it off, allow the oil to drain down from the top end by waiting a few minutes. Bikes with a sight glass require that you hold the bike level – either from the saddle or beside the bike – look at the window conveniently located on the bottom of the engine to make sure the oil level is between the two marks on the case. (Tip: If your bike has both a centerstand and a sight glass, measure it the above way and then compare it to the level shown while on the centerstand. This way you can use that level as reference so can check the oil level when it’s parked on the centerstand in your garage.)
For engines with a dipstick, check your owner’s manual to make certain how the stick is to be inserted for an accurate reading. Usually, you will wipe the stick and insert it into the case until it makes contact with the filler plug’s threads. Be sure the plug is straight and the bike is level or you may get an inaccurate reading.
If you ride your bike regularly, you should check its oil at least weekly. If you ride infrequently, consider checking before every ride. With regular checks, you are more likely to notice symptoms of little problems before they get bigger.
Read more about How Do You Check A Motorcycle’s Oil Level? at Motorcycle.com.
Motorcycle.com is offline   Reply With Quote Quick reply to this message
» Recent Discussions
Lightmode kit
02-22-2017 11:26 AM
by Redbeam
Last post by Redbeam
Today 07:27 AM
6 Replies, 82 Views
? for those that have...
02-23-2011 09:55 PM
Last post by ZX7-Mike
Today 05:38 AM
9 Replies, 2,487 Views
2005 Kawasaki ZX6R 636...
05-10-2012 11:59 PM
Last post by terpguy78
Today 03:25 AM
5 Replies, 1,842 Views
2013 Kawasaki Ninja 650...
Yesterday 10:31 PM
Last post by philiphil
Yesterday 10:31 PM
0 Replies, 14 Views
ER6n -08 engine cutting...
Yesterday 06:04 PM
Last post by Kristian Storseth
Yesterday 06:04 PM
0 Replies, 37 Views
Yesterday 05:50 PM
Last post by Blake Dalton
Yesterday 05:50 PM
0 Replies, 19 Views
Hi all
Yesterday 03:51 PM
Yesterday 03:51 PM
0 Replies, 18 Views
ZX9 B Won't start
Yesterday 02:28 PM
Last post by Thehighlander123
Yesterday 02:28 PM
0 Replies, 16 Views
Hi All
Yesterday 02:23 PM
Yesterday 02:23 PM
0 Replies, 44 Views
FS: 2009 zx6r - $3,600
Yesterday 01:00 PM
Last post by Jvello15
Yesterday 01:00 PM
0 Replies, 20 Views
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
