Reputation system - KawiForums - Kawasaki Motorcycle Forums
post #1 of 56 (permalink) Old 12-12-2007, 12:28 AM Thread Starter
MODERATOR
hoser's Avatar
Reputation system
a little info on the rep system
Originally Posted by admin View Post
"Reputation system". This feature allows members to "rep" people for good posts and bad. The higher someone's rep is the more valuable the members feel their contributions are. This is a quick way for new and long time members to see who is contributing to the community.
The rep power is weighted based on the factors below:
Register Date Factor
For every 20 days, users gain 1 point of reputation-altering power.
Post Count Factor
For every 500 posts, users gain 1 point of reputation-altering power.
Reputation Point Factor
For every 100 points of reputation, users gain 1 point of reputation-altering power.
Minimum Post Count
A user must have 50 posts before they can affect other's reps.
Minimum Reputation Count
What you must have before you can rep others. Set to 10 which we all have when we join.
To add to rep click on the "scales" icon below the user's profile on the left of their posts and rep is displayed under the member's post count on the left as a bar graph kind of graphic.
Red means someone disapproved of your post and that this had a negative impact on your overall reputation score.
Green means someone approved of your post and that this had a positive impact on your overall reputation score.
Gray means someone either approved or disapproved of your post and this had NO impact on your score. Why would this happen? Currently, you have to have a certain number of posts before you are allowed to have ratings that impact others.
the info below has not been confirmed by the admin yet, so consider it as a guide more than a FAQ for now.
What is the purpose of the reputation system?
In short, it separates the jokers (the bad ones anyway) to the thinkers. To the people with more points, it makes their posts “stronger” Some forums may have some kind of prizes, usually an additional forum feature that nobody else has but I don’t think there is a prize on this forum or else it would be heard of.
What are reputation points?
On the bottom right corner of everyone’s post on any thread, there is a “%” button. When you click it, a pop up box appears and asks what you think of that user’s post. Then you can check either “I Approve” or “I Disapprove”. Then if you want, you can leave a comment in the text box below. If you click on your own “%” sign, it will show you how much reputation you received for that post.
Do I have to participate in the system?
No. This is an optional feature that can only be encouraged to be used. Of course there are many people that don’t care about it what so ever, and some people think its just silly to have “reputation” on the “internet”.
How can I see my reputation points?
If you go in your user control panel, it will be on the right side under your subscribed threads. In the right corner of it, it will show your total points (new users start off with 10 points of positive). It will also show you the last 5 reputations you received by thread title, date, and the other users comment. (Note that the admin setting right now is that you cannot see the name of the person that gave you the reputation, unless they put their name in the comment box)
How do I see other people’s rep points?
You cannot see their exact numbers. However, you can see the number of squares beside the user’s name where the more green squares mean higher reputation, and red squares mean a negative point value. If you want to know how all members rank in reputation, just go to the members list and click on “reputation” to sort by descending reputation.
How Do I know what kind of reputation I received?
In your user cp in the left column where it shows reputation, there are squares. A green square is positive, red is negative, and white is neutral, from a user with less than 50 posts or from a user with a negative reputation score.
How much reputation can I give?
If I am correct, you can give out 10 times in 24 hours, and must give out to 20 different users before you can give to one user again. (this is what I think the numbers are set as, if you figured out different from personal experience let me know.) This prevents people from abusing the system. But of course any man made system isn’t perfect. But an admin can rate as many people as many times as they wish.
Do different users give different amounts of points when they give reputation?
Yes, this is how it works.
- Members with less than 50 posts give neutral reputation (zero points)
- Members over 50 posts give 1 point for positive and -1 point for negative
- Every 1000 posts increases the members reputation weight by 1
- Every 100 reputation points increases the members reputation weight by 1
- Every year of membership increases the members reputation weight by 1
- Administrators reputation weight is defaulted at 10 points (I think)
- Members with negative reputation gives neutral points
Example: A user that has 210 rep points, has been here for just over 1 year, and has 3300 posts would give out 7 points of positive or negative of reputation (since 1 initial point + 2 from their own reputation + 1 from the year + 3 from posts.)
How does one get more green squares under their name?
At 100 reputation points, one will get an additional green square. After every 100 reputation points, an additional square will be added. After so many (I think 5 squares) then the square adding sequence jumps to every 200 points. I forgot the maximum number of squares someone can get, but I think its 10 or 11.
How come the monikers are different when I put my cursor over different people’s square(s) under their name?
That is another factor how to see someone’s reputation that I haven’t explained in the “How do I see other people’s rep points?” section. This is how it goes:
-99999 points = User is infamous around these parts
-50 points = User can only hope to improve
-10 points = User has a little shameless behavior in the past
0 points = User is an unknown quantity at this point
10 points = User is on a distinguished road
50 points = User will become famous soon enough
150 points = User has a spectacular aura about
250 points = User is a jewel in the rough
350 points = User is just really nice
450 points = User is a glorious beacon of light
550 points= Users name is known to all
650 points = User is a splendid one to behold
1000 points = User is much to be proud of
1500 points = User has a brilliant future
2000 points = User has reputation beyond repute
When should I give people positive reputation?
When a user makes a well thoughtful post worth reading. You might not agree what is said, but the post might really stand out in the topic. Or a person may have created a very good thread that made the forum worth visiting to read. Also whenever someone helped you in some way, as in tech help or gave you files or something in that nature. Just because someone is your friend is not a good enough reason to give reputation.
Then when should I give negative reputation?
A post that should recieve negative reputation is where someone does not follow the topic. A “troll” post that was just meant to give an outrage of flames from everyone else, or users that just fight in a thread. Just because you dislike a user isn’t a good reason to give bad reputation.
Should I give you receive reputation for this thread?
Well, if it helped you and you think it deserves one, then go ahead. If you found this thread through a link, then whoever gave you that link should get the points and leave it at that.
hoser is offline
post #2 of 56 (permalink) Old 12-12-2007, 12:30 AM
Mike_Diako's Avatar
Location: Manchester, CT ..... 20k+ Miles .... 2002 zx6r
Send a message via AIM to Mike_Diako
can we make this a sticky. a little to hard to remember exactly how it works
One Big Ass Mistake, America
Mike_Diako is offline
post #3 of 56 (permalink) Old 12-12-2007, 12:33 AM Thread Starter
MODERATOR
hoser's Avatar
sure thing
hoser is offline
post #4 of 56 (permalink) Old 12-12-2007, 12:34 AM
Mike_Diako's Avatar
thanks.
at what intervals will the green squares multiply?
post #5 of 56 (permalink) Old 12-12-2007, 12:45 AM
ratherberiding
joonyaboy's Avatar
Send a message via Yahoo to joonyaboy
Seems like a fantastic idea
"I always feel a little better after a ride" ~52k miles so far
joonyaboy is offline
post #6 of 56 (permalink) Old 12-12-2007, 01:01 AM Thread Starter
MODERATOR
hoser's Avatar
first post updated, still need admin to verify though so i might be way off.
hoser is offline
post #7 of 56 (permalink) Old 12-12-2007, 10:46 AM
collinjoseph's Avatar
Hopefully I didn't miss this in the O.P. but, here goes. I see that new users start out w/10 rep points and I zero. I was thinking "okay, maybe I got 10 negative" but, in my user CP, I only see one rep point given to me and this is my 2nd question. The box was black or grey (no comment), what would that mean?
Thanks for taking time to answer.
P.S. I see Skywalker has like 2000 of these already, he must cheating.
It was just a joke Skywalker, no negatives...no...don't you do it...damn.
collinjoseph is offline
post #8 of 56 (permalink) Old 12-12-2007, 11:35 AM
Powerhungry
nevada's Avatar
Originally Posted by collinjoseph View Post
Hopefully I didn't miss this in the O.P. but, here goes. I see that new users start out w/10 rep points and I zero. I was thinking "okay, maybe I got 10 negative" but, in my user CP, I only see one rep point given to me and this is my 2nd question. The box was black or grey (not comment), what would that mean?
yeh ive noticed this too. NEW members start with 10. i think its a system flaw. in the end it WILL work itself out.
hell, ive only got 30 something. its really not a big deal tho.
the longer your active on the site, and NOT an asshat, then the more points that you'll accumulate.
this rep system is BRAND new for US. it will take some time, but things will level out.
ERIN
nevada is offline
post #9 of 56 (permalink) Old 12-12-2007, 12:29 PM
Administrator
admin's Avatar
All new users start out with 10 rep points. As your rep points increase your repping power does as well so a person with 500 rep points carries more weight repping a post than someone with only 10. You can see the intent here...it's a way of recognizing members who actively contribute with posts of value.
Can it be abused? Yes, but this is where the mods and community members step in. If we see some abuse going on we will do exactly what I've seen this community do all along...act in the best interest of the community as a whole. Knowing this, I have few fears.
Do you need me to update the text above? I've not changed the rep values. All I did was make the text literal to say: user has at least X amount of rep points. That's as clear as I can make this one.
admin is offline
post #10 of 56 (permalink) Old 12-12-2007, 12:39 PM
Thanks for takin' time admin, my original question was:
A new user starts w/ten points but, it seems that a user who was here before the rep. points were started starts w/0. It is not a big deal at all, I just thought that I'd bring it up in case it was a mistake.
Edit: I also could be wrong all together on this. I didn't look to far into this.
