//// need help with 07 500r //// - KawiForums - Kawasaki Motorcycle Forums
post #1 of 2 (permalink) Old 11-11-2012, 09:27 PM Thread Starter
Hello I purchased a used 2007 ninja 500r with 4,153 miles two weeks ago. When i drove this bike home I noticed cruising at 50 mph the bike would hesitate a bit every once in a while. Also stopping at the stop light the bike would idle at 3,000 rpms. I got the bike in the garage changed oil, spark plugs, air filter and sprayed the carbs with carb cleaner. I did not take carbs apart because exterior looked really clean. After i reassembled the bike is hard to start. I can start it by turning off fuel, and with choke off. Engine turns on and revs up to 4000rpms and eventually shuts off. I have adjusted throttle screw, switched fuel to on position and still get same result. I need help! Thanks and Happy Veterans Day!!!
MARCOPOLO830 is offline
post #2 of 2 (permalink) Old 11-12-2012, 12:17 AM
Sovereign is offline
You may post new threads
