Dirty rims : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-11-2012, 09:19 PM   #1 (permalink)
Decay has at least 10 rep points
Default Dirty rims
How do you clean your colored rims? Seems like every time I lube my chain the rims get dirty and can't get into the center to clean them. Any advice?
Decay is offline   Reply With Quote
Old 11-12-2012, 09:32 AM   #2 (permalink)
av8r-92's Avatar
Take Simple Green (don't dilute it) and spray the wheel down. Let it dry completely. Then take a rag and wipe the wheel down; the grease comes off in a dust. Rinse the wheel again with water and it'll be clean.
I've tried using Simple Green when it was still wet and it was a major bitch. Let it dry though, and the grease comes right off.
-Will
KEEP CALM AND CHIVE ON
"Trust me; I'm a pilot."
Old 11-12-2012, 09:40 AM   #3 (permalink)
zx7r_raz has at least 10 rep points
I Just use wd40 oil spray some on a rag or cloth wipe off the muck just don't get it on your tyre !
Well it was mint till i lowsided the bike
zx7r_raz is offline   Reply With Quote
Old 11-12-2012, 10:09 AM   #4 (permalink)
zvenkruspe's Avatar
Yep WD-40... it smears at first but after getting most of the dirt of, just keep rubbing off the smears with a fresh paper towel. the WD-40 residue will do the job.
I got yellow rims. PITA but so pretty once they shine back in bright yellow.
BTW, I can say pretty cuz I'm a girl
Old 11-12-2012, 09:34 PM   #5 (permalink)
av8r-92's Avatar
That's why I don't like WD-40.
-Will
Old 11-12-2012, 10:52 PM   #6 (permalink)
ZX6RRNewbie's Avatar
Yep WD40 FTW
from BEAUTIFUL AUSTIN TEXAS
2006 Lime Green ZX6R
Old 11-12-2012, 11:38 PM   #7 (permalink)
racerboy88's Avatar
racerboy88 has between 5,000 and 7,500 rep pointsracerboy88 has between 5,000 and 7,500 rep pointsracerboy88 has between 5,000 and 7,500 rep pointsracerboy88 has between 5,000 and 7,500 rep pointsracerboy88 has between 5,000 and 7,500 rep pointsracerboy88 has between 5,000 and 7,500 rep pointsracerboy88 has between 5,000 and 7,500 rep pointsracerboy88 has between 5,000 and 7,500 rep pointsracerboy88 has between 5,000 and 7,500 rep pointsracerboy88 has between 5,000 and 7,500 rep pointsracerboy88 has between 5,000 and 7,500 rep points
I use WD-40 to clean rims before I wash my bike
Fuelled by rice
racerboy88 is offline   Reply With Quote
