need advise : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-14-2012, 03:53 PM   #1 (permalink)
kawigurl<3 has at least 10 rep points
Default need advise
i messed up a bearing in my engine idk which would be easier or cheaper to replace that or get a whole new engine?
kawigurl<3 is offline   Reply With Quote
Old 11-14-2012, 05:45 PM   #2 (permalink)
BlackDog's Avatar
BlackDog has between 10,000 and 20,000 rep pointsBlackDog has between 10,000 and 20,000 rep pointsBlackDog has between 10,000 and 20,000 rep pointsBlackDog has between 10,000 and 20,000 rep pointsBlackDog has between 10,000 and 20,000 rep pointsBlackDog has between 10,000 and 20,000 rep pointsBlackDog has between 10,000 and 20,000 rep pointsBlackDog has between 10,000 and 20,000 rep pointsBlackDog has between 10,000 and 20,000 rep pointsBlackDog has between 10,000 and 20,000 rep pointsBlackDog has between 10,000 and 20,000 rep points
I would recommend getting another engine...
the repair of the bearings alone might not correct any other damage from when the bearing failed, if that is what happened??
and finding a reputable, experienced, capable mechanic is difficult.
even the dealer had rebuilt a warranted engine three times for us before replacing it with another
its possible they/someone could repair it, give it to you, and then while driving down the road, "kaboom",... start all over again, $$$
and finding a motor can be a pain too...
Good Luck !!
"Let the Good Times Roll"
BlackDog is offline   Reply With Quote
