250R - Startup is a hassle : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-26-2012, 01:28 PM   #1 (permalink)
knoob has at least 10 rep points
Default 250R - Startup is a hassle
I have a 2003 250R and in this cold Bay Area weather (55F ), startup is a pain. I give it half-choke for about 30 seconds, then pull the choke off and let it idle for a few minutes, then start riding.
But my neighborhood is full of stop signs. My first ride off is 1st/2nd gear for about 30 seconds @ ~25 mph, then I come to a stop sign. I downshift from 2nd to 1st to stop, then the engine stalls. I restart it (which happens quickly), turn right, go 100 ft till the next stop sign. Engine stalls. Restart it, turn right at a stop light. Go about 1000ft (3rd), and _maybe_ if I'm lucky the engine has warmed up enough that it won't stall when I'm idling. After this it generally behaves as the temperature bar is ~40%. Sometimes I have to rev the engine while I'm clutching and downshifting to 1st, to prevent the engine from stalling.
Anyone know what I should do to remedy this? Thanks.
knoob is offline   Reply With Quote
Old 11-26-2012, 01:31 PM   #2 (permalink)
Powerhungry
nevada's Avatar
raise the needle.
search the site, there are many threads.
also, leave the choke ON, even while you're riding, until its up to temp, and wont stall.
as long as you remember to turn it off once its warmed up, it wont hurt anything.
also, what is the WARM idle at? it might be a bit low, bump it up some, that could help.
Old 11-26-2012, 03:50 PM   #3 (permalink)
Thanks, this seems like exactly what I need. Warm idle is at about 1krpm -- is that too low? Leaving the choke on while riding till warm does solve the problem, but I searched somewhere here where it said not to do that. Guess it's a matter of preference.
Old 11-26-2012, 03:53 PM   #4 (permalink)
Powerhungry
nevada's Avatar
i think 1k is a bit too low.
i dont have one, but id guess it should be closer to 1500.
Old 11-26-2012, 04:29 PM   #5 (permalink)
It should be 1250 RPM IIRC.
Currently own:
05 Z750S
Have owned:
01 Volusia
Old 11-26-2012, 07:09 PM   #6 (permalink)
KawiAdrian's Avatar
KawiAdrian has at least 50 rep pointsKawiAdrian has at least 50 rep pointsKawiAdrian has at least 50 rep points
There is nothing wrong with leaving the choke on while riding until it is warm. Just don't forget to turn it off when up to operating temp. I grew up on a farm with old tractors and atv's and i have been doing this for years. Not one single problem from it. ever.
The views, comments, and opinions posted above represent soley the views, comments, and opinions of myself alone, and to my knowledge do not represent the views, comments, and opinions of anyone else
KawiAdrian is offline   Reply With Quote
Old 11-26-2012, 09:52 PM   #7 (permalink)
Ok, thanks. I will do it from now on.
Old 11-27-2012, 06:25 AM   #8 (permalink)
It's not rocket surgery.
LarryJ's Avatar
A rejet won't hurt either, or at least get the idle mixture screws on the carbs turned out a couple of turns. This helps with cold start up as well. When you get those set correctly you shouldn't need the choke to start the bike until you get down to 50° or lower.
And yes, keep the choke on for about the first mile or so, or until you've gotten past all those pesky stop signs. Also, you're wasting time and fuel by letting the bike sit and warm up for several minutes at a time. Open the choke, start the bike, get your helmet and gloves on, take off, then shut off the choke as described earlier.
Now that it's cold, make sure your tire pressures are correct. A bit off topic, but it's something people tend to forget about when the temps dip down in the winter.
Old 11-27-2012, 01:46 PM   #9 (permalink)
chris140's Avatar
Personally I open the choke all the way while i put my jacket and gloves on. No need for any throttle, the revs will shoot up but as the bike gets up to running temp, the choke will pull back to about half way on its own. I slip the choke back another quarter and ride off.
Two advantages to this.
1. As i said in another post, by getting your jacket and gloves on outdoors you are acclimatising yourself to the outside temperature especially first thing in the morning when youve been tucked up in bed all night.
2. I'm the impatient type and hate standing around scratching my head waiting for the bike to get up to temp.
Not saying the others are wrong, just this is what I do.
