New rider...already having problems :/ - Page 2 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 12-05-2012, 08:45 PM   #11 (permalink)
justin0989's Avatar
justin0989 has at least 10 rep points
got ya. only had a gsxr lol still a noob only been riding for like half a season
justin0989 is offline   Reply With Quote
Old 12-05-2012, 08:56 PM   #12 (permalink)
av8r-92's Avatar
Originally Posted by Garibay View Post
That shouldnt matter though because it should still give the same miles per gallon
Yeah, I realized that a few minutes later. It is better to calculate on a full tank, though; you get a better average.
-Will
KEEP CALM AND CHIVE ON
"Trust me; I'm a pilot."
Old 12-05-2012, 10:03 PM   #13 (permalink)
sckrocodile's Avatar
sckrocodile has at least 10 rep points
I'd go through and get a full tune up done. Spark plugs, oil, oil filter, air filter, run a couple tanks of premium gas through it. It wont hurt it and will absorb some of the gunk in your engine. Being that you are calculating less than half what it should be i'd probably check how your measuring it.
sckrocodile is offline   Reply With Quote
Old 12-05-2012, 10:49 PM   #14 (permalink)
av8r-92's Avatar
This won't do shit. It's not cleaner-burning and it won't have any detergents that regular doesn't have.
This might do shit. Also, try putting some Sea Foam in the gas. That tends to clean out some crap in the fuel system.
Second part's a possibility, as well. OP, how are you calculating it?
-Will
Old 12-05-2012, 11:38 PM   #15 (permalink)
Garibay's Avatar
Garibay has at least 10 rep points
Yea i will change the sparkplugs or at least check to see they are ok, and check the air filter
I read about that sea foam stuff the other day and was planning on putting some in as well
Well if im using up 2.9 gallons of gas in 78 miles, 78 divided by 2.9 gives me about 27 mpg
Garibay is offline   Reply With Quote
Old 12-05-2012, 11:54 PM   #16 (permalink)
randy218's Avatar
randy218 has at least 2000 rep pointsrandy218 has at least 2000 rep pointsrandy218 has at least 2000 rep pointsrandy218 has at least 2000 rep pointsrandy218 has at least 2000 rep pointsrandy218 has at least 2000 rep pointsrandy218 has at least 2000 rep pointsrandy218 has at least 2000 rep pointsrandy218 has at least 2000 rep pointsrandy218 has at least 2000 rep pointsrandy218 has at least 2000 rep points
Are you riding around in 2nd gear the whole time?
randy218 is offline   Reply With Quote
Old 12-06-2012, 12:19 AM   #17 (permalink)
ekimgb has at least 10 rep points
Dont know much about bikes in a way but there is an o2 sesor right? To me the computer is telling it to put to much fuel in? I may be wrong but doesnt that make some sense?
ekimgb is offline   Reply With Quote
Old 12-06-2012, 12:25 AM   #18 (permalink)
Alex Smith's Avatar
Alex Smith has at least 10 rep points
Thats really odd. Im not sure if it is fuel injected but thats probably part of your problem. It would help a lot to put fuel injector cleaner in there.
Alex Smith is offline   Reply With Quote
Old 12-06-2012, 01:02 AM   #19 (permalink)
Garibay's Avatar
Well i ride in town mostly so usually around second and third gear sometimes 4th in bigger roads
And yes i sure will put some cleaner
Old 12-06-2012, 01:03 AM   #20 (permalink)
Garibay's Avatar
I thought of this too but how would i know if its that?
