New rider...already having problems :/ - Page 3 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 12-06-2012, 01:15 AM   #21 (permalink)
If it was running that rich there would be some more symptoms like smelling of fuel, fouling plugs, and not running right. Maybe you have a leak somewhere?
Old 12-06-2012, 01:22 AM   #22 (permalink)
Garibay's Avatar
Garibay has at least 10 rep points
I always check under the bike before i get on and havent seen one...other than water...maybe its leaking while running only??
Garibay is offline   Reply With Quote
Old 12-06-2012, 01:22 AM   #23 (permalink)
ekimgb has at least 10 rep points
Regarding exhaust sensors on the Ninja 650R and ER6n
so im wrong no o2 sesor but i still think a sensor is the cause. hopefully someone with a little more knowledge will chime in. map sensor or air temp sensor?
ekimgb is offline   Reply With Quote
Old 12-06-2012, 01:25 AM   #24 (permalink)
that would be a pretty bad leak imop quite noticeable
Old 12-06-2012, 01:30 AM   #25 (permalink)
If it was just dumping fuel, you'd notice a really really rich smell when you got off of it. (Like riding behind a 70s muscle car.)
Like mentioned above, air filter, spark plugs, check your chain tension, make sure your wheels spin fairly freely (they'll always have some resistance), and go from there.
Currently own:
05 Z750S
Have owned:
01 Volusia
Wrider is online now   Reply With Quote
Old 12-06-2012, 01:41 AM   #26 (permalink)
ShinobiJeh's Avatar
Originally Posted by chris140 View Post
I'm not big on American geography, from what little I know about it California is supposedly "the sun shine state". How cold is it there at the moment? Have you been using the choke much, have you been letting it idle for extended periods without moving?
The bike is fuel injected, no choke. And whenever I fill up my 07 650 at fuel light, about 3 gallons gets me +-155mi.
You are not shifting at red line right? Shift around 4-4.5k for a tank of gas and see if that changes anything. Also may want to try running some seafoam in the fuel. I did that after purchasing my 07 and it seemed to run smoother.
Also check tire pressure. I run around 40psi vs tires saying 36ish. A little bit higher pressure will improve mpg but give slightly less grip. But don't go putting in 50+ psi (that's a good way to pop a tire).
Old 12-06-2012, 01:44 AM   #27 (permalink)
Garibay's Avatar
No not running rich i dnt think
Do they sell something to check the chain tension?
When moving the bike with my feet with the clutch in u can feel a bit of resistance i guess, i'll check tomorrow if the brakes smell like burned or something but i doubt it
Old 12-06-2012, 01:49 AM   #28 (permalink)
Garibay's Avatar
Thats like double what i get!
No, i shift like at 5 or 6 except 1st gear that one lower
I will for sure try sea foam, a few ppl have recomended it
Tire pressure was low in like high 20s but i put them to 40 psi a few days ago
Old 12-06-2012, 02:06 AM   #29 (permalink)
ShinobiJeh's Avatar
Get a ruler, put bike in N and on sidestand. Go to chain and put ruler at 1inch. Try moving the chain up and down and see how far it moves each way. You have to do this the whole length of chain so you will have to roll your bike forward or back whike doing this (why it's in neutral).
There is a recommended distance of motion i forget i think around 1.5inches. You have to do both the top part of chain and bottom.
Look up on google checking chain slack, I'm sure there will be some good tutorials.
The more I'm hearing it sounds like it could def be some mechanical problem, check if brakes are hot (carefully) after a few mile ride. Also do you ever try coasting? Like when you are approaching stoplight or sign? Coast by holding clutch, not by putting in N.
Old 12-06-2012, 02:22 AM   #30 (permalink)
Garibay's Avatar
I'll check the chain then see if thats ok
No i've never done that, when stoping at a light or stop sign i use the clutch
Thats what im affraid of that it will be something expensive to fix
