New rider...already having problems :/ : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 12-05-2012, 07:36 PM   #1 (permalink)
Garibay's Avatar
Garibay has at least 10 rep points
Exclamation New rider...already having problems :/
Hello my names Jorge. I've been riding for about 3 months now, which is not long at all. I have a 09 ninja 650r (which Is my 1st bike). The bike is great and i love it yet for some reason it's wasting a lot of gas!! I've been getting in the high 20s every fill up! I don't ride hard at all and its pretty much all city driving since I mostly use it to go to and from school. I havent had time to check much since im in school, but im going to take it back home this weekend and either look myself or take it to a mechanic. Any ideas on what the problem can be?
Any help would be appreciated! Thanks
Garibay is offline   Reply With Quote
Old 12-05-2012, 07:48 PM   #2 (permalink)
ZX6R>CBR's Avatar
Has it always gotten bad mileage since you bought it or is it just recently? Because it should be getting near 50mpg or higher
ZX6R>CBR is online now   Reply With Quote
Old 12-05-2012, 07:51 PM   #3 (permalink)
chris140's Avatar
Hi Jorge, welcome to the forums.
I'm not big on American geography, from what little I know about it California is supposedly "the sun shine state". How cold is it there at the moment? Have you been using the choke much, have you been letting it idle for extended periods without moving? What rev does it idle at?
You said you've been riding for 3 months but its an 09 model so its 3 going on 4 years old, which leads me to assume you bought it second hand. Do you know anything about its history? Has it got any dents in the fuel tank or any leaks around the fuel lines?
There's a whole host of people with more technical knowledge than me around here but those are the first things that come to my mind.
Old 12-05-2012, 07:55 PM   #4 (permalink)
RebelYJ has at least 10 rep points
That's terrible mileage for a 650, I regularly got -45 with a city/highway mix. Make sure when you fill up you fill to the same level somewhat consistently. I used fuelly to track mine which is all odometer based and no worries over resetting the trip.
Best advice is to keep riding smooth. But even when I rode hard I never got that low. You either have a leak somewhere or are calculating something wrong...?
Green Machine (Kawasaki Ninja 650R) | Fuelly
Chris> I had an 09 also here in CA, it's fuel injected so no choke adjustment required on warmup.
2012 ZX6R Green w/ Targa FE
RebelYJ is offline   Reply With Quote
Old 12-05-2012, 08:09 PM   #5 (permalink)
Garibay's Avatar
thanks for the answers
to answer some of the questions:
-Yea i bought it used and has always given me that milage.
-I changed the oil when i bought it
-I fill it up with regular gas 87 i think it is? fill it to the splash guard i believe its called (right to the top when on the stand)? i pretty consistently put in 2.9ish gallongs when the E light flashes the first time (at about 78 miles)
-It has no dents on the gas tank, but it did have some scratches on the left fender and a bit on one of the round motor guards (nothing bad)
- It is all stock
-I checked the tire pressure which was low so i filled them to about 40 psi but that shouldnt have had that much of an impact on the mpg
- it runs good and has never backfired
-i plan on checking the spark plugs sometime next week.
Old 12-05-2012, 08:12 PM   #6 (permalink)
chris140's Avatar
Thanks mate, never ridden or owned one. That's why I tend to defer to other peoples experience but just wanted to put my thoughts across just in case
Old 12-05-2012, 08:34 PM   #7 (permalink)
av8r-92's Avatar
- It is all stock
You fill it while it's on the kickstand? If so, there's yer problem.
-Will
KEEP CALM AND CHIVE ON
"Trust me; I'm a pilot."
Old 12-05-2012, 08:36 PM   #8 (permalink)
justin0989's Avatar
justin0989 has at least 10 rep points
not sure about 650's but i think the problem is that ur puting regular in shouldnt all bikes take the highest grade?
justin0989 is offline   Reply With Quote
Old 12-05-2012, 08:39 PM   #9 (permalink)
av8r-92's Avatar
Negative. Whatever the manufacturer recommends you should put in, you should put in. Super sports tend to take premium (and of course, this is open to argument), and the other stuff can take regular.
Putting regular in a high performance engine may cause detonation. Putting premium in an engine that doesn't need it does nothing.
-Will
Old 12-05-2012, 08:43 PM   #10 (permalink)
Garibay's Avatar
-Will
That shouldnt matter though because it should still give the same miles per gallon
