Removing decal on tank : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 12-25-2012, 02:05 PM   #1 (permalink)
BruceShapiro has at least 10 rep points
Default Removing decal on tank
Just bought a 2012 ZX 6R and thinking about removing the Ninja decal on the tank. I'm told that the decal is below the clear coat however. Anyone have any advice as to how you can remove the decal that is below the clear coat?Thanks very much.
Bruce
BruceShapiro is offline   Reply With Quote
Old 12-25-2012, 03:20 PM   #2 (permalink)
Jeff in Kentucky's Avatar
Some use a razor blade around the edges of the decal to cut through the clear coat, then a hair dryer and a plastic razor blade.
This guy below used a dremel tool with an added dimmer switch to slow it down:
How To Remove Decals Under Clearcoat - Mtbr Forums
Old 12-25-2012, 08:04 PM   #3 (permalink)
ER^NSLIMS's Avatar
ER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep points
Jesis, the last thing I would do to a new bike would be cutting through the clear
Sent from my HTC Glacier using Motorcycle.com Free App
New out of the box Triumph S3.
ER^NSLIMS is offline   Reply With Quote
