Hi I'm new here so please bare with me. I have a 1982 kz750 spectre, once my bike is hot, my oil light will come on in second gear through fourth and then shut off one I shift into 5th. I tried changing my oil and replaced the oil filter, and it still does this. Once in a while it won't do it, but more often than not. What's going on here?
There will be a spot on the engine that allows you to insert an actual oil pressure gauge. Need the service manual for that, cause you need to know where and what you should be showing.
I assume that your oil level is correct, and you're using the filter that you're supposed too? When was the last time the oil was changed?
